Broke the DAMN bolts! HELP
Old Oct 10, 2007 | 05:37 PM
turbosol18's Avatar
Default Broke the DAMN bolts! HELP
so i was installing my lower control arms on my del sol and while removing one of the bolts it broke off now im stuck...what can i do?
Old Oct 10, 2007 | 05:45 PM
92hatchboi's Avatar
Default Re: Broke the DAMN bolts! HELP (turbosol18)
if it is the bolt that holds the strut. thats a common problem on the hondas. ur gonna need to change the control arm or if u wanna sit there with an easy out and try to take it out its up to you
Old Oct 10, 2007 | 05:46 PM
1992Si's Avatar
Get a small propane torch from the hardware store. heat the area around the bolt and try and drive the bolt out with a punch and hammer.
I should first ask which bolt ?
Where the shock mounts or where the arm mounts to the frame ?
Old Oct 10, 2007 | 05:48 PM
turbosol18's Avatar
Default Re: (1992Si)
the bolt that broke is on the shock bracket
Old Oct 10, 2007 | 05:52 PM
92hatchboi's Avatar
Default Re: (turbosol18)
i told u what ur options are. ive seen this happen too much
Old Oct 10, 2007 | 06:50 PM
turbosol18's Avatar
Default Re: (92hatchboi)
im trying to remove my stock ones to put my aftermarket control arm but it wont come off untill i get those bolts some how
Old Oct 10, 2007 | 08:14 PM
vtecthiss's Avatar
bumb
thundernoodle
Jul 10, 2010 03:54 PM
streetracerjoey210
Jul 7, 2006 10:30 PM
b_serious
Oct 22, 2005 11:27 PM
Snail EK
Nov 12, 2004 12:11 PM
VTECorona
Aug 5, 2002 06:17 PM
