will a dx head bolt up to a cx bottom end?
same engine...
but he was right...they are the exact same engine....so go for it
um, noooooo...
96-00 the "CX" and "DX" engines are the same, (D16Y7)
the 92-95 the "CX" and "DX" engines are different, (D15B7 = DX, D15B8= CX)
CX has a 8 valve head, and VERY small intake manifold and throttle body
DX has a 16 vavle head and a larger intake manifold and throttle body.
The 92-95 "DX" head WILL bolt up to your "CX" bottom like it is ment to be there since they are from the same series. Just get a new head gasket and head studs and you are fine.
he didnt know so shut the fawk up......
thankx for the help and yes i have the 8 valve cx which is very shitty.
Yes I second that it will fit just fine, and your intake will bolt up to it as well, but i wouldn't recommend it. Get the intake manifold and the throttlebody from the dx. There is a HUGE port size difference. I did it once and was pretty impressed at the mini-mini-me did. A high compression dx motor is what you will be making.
i heard it will bolt up but it won't work. the CX pistons only have releifs for 2 valves per piston...
can anyone else verify this???
sohcvtec66
10
Apr 5, 2004 10:23 AM
MissLady
22
Oct 23, 2003 07:01 AM
B2FiNiTY
Apr 24, 2002 01:02 PM
