Can anyone help me diagnose this problem?
Old Jun 19, 2002 | 07:59 PM
NWPNOMORE's Avatar
Banned
Default Can anyone help me diagnose this problem?
Recently my car started making a clicking noise similar to the way an axel sounds when its crapped out. However, it only happens when I am slowing down to a complete stop. Just to rule out the axles, I replaced the side where the clicking was coming from but that didn't fix the problem. It doesn't make any noise on turns, only when I am breaking at very low speeds. Any ideas guys? Thanks.
Old Jun 19, 2002 | 08:02 PM
Reid's Avatar
Global Moderator
Default Re: Can anyone help me diagnose this problem? (NWP4LIFE)
Being that it's related to speed, all of your front brake equipment is up to par?
Old Jun 19, 2002 | 08:09 PM
NWPNOMORE's Avatar
Banned
Default Re: Can anyone help me diagnose this problem? (Reid)
everything looks alright, my rotors are a little warped though.
Old Jun 19, 2002 | 08:11 PM
Reid's Avatar
Global Moderator
Well replace those first and let us know if the problem persists.
I can't see how that would really contribute to the sound you're describing, but it wouldn't help to change them out anyway.
Old Jun 19, 2002 | 08:14 PM
GSR901's Avatar
maybe bushings being worn
Old Jun 19, 2002 | 09:54 PM
Reid's Avatar
Global Moderator
Default Re: Can anyone help me diagnose this problem? (B18Cwon)
Wheel bearing maybe? Does it sound like metal to metal contact?
Old Jun 19, 2002 | 10:06 PM
01PYITR's Avatar
Anyhow... Allways start with the broken stuff and then you will have a fresh start to look for the click noise.
Fix the rotor and that might get rid of the sound, it could cause the pads (if really warped) to shift around and make noise...
Yes Reid said the same thing, just want to renforce it.
Old Jun 19, 2002 | 10:13 PM
beeboyee's Avatar
Default Re: Can anyone help me diagnose this problem? (01PYITR)
check your CV boots (axles, ETC.)
Old Jun 19, 2002 | 10:37 PM
fowler!'s Avatar
just don't slow down
Old Jun 20, 2002 | 09:37 AM
NWPNOMORE's Avatar
Banned
Default Re: Can anyone help me diagnose this problem? (fowler)
the sound does make me not want to stop, but every once in a while I have to get gas.
Old Jun 20, 2002 | 04:08 PM
Reid's Avatar
Global Moderator
Changed the rotors yet?
Old Jun 20, 2002 | 07:29 PM
ITR21's Avatar
check your balljoints
Old Jun 20, 2002 | 07:38 PM
01PYTypeR#1140's Avatar
From: Couple SW99 40 Cal. For Ya, Do Ya Really Want It.., NJ, U.S.A
__________________________________________________ __________________
When I pull off from a stop or accelerate, I get a click noise coming from the wheels. It is just a sharp "click", almost like a chirp. It is not continuous. a few clicks and it stops.
Well, after 3 days Acura gives me back the R, and guess what it's fixed! I asked them what the problem was and thay said they didn't know They pulled my axles to replace them, but mine were in perfect condition so they reinstalled them, and checked the vehicle again the noise was still there. So they lifted her back up and torqued everything up front to spec. and he said I mean everything, and when they took her out again problem solved. He told me to keep him posted, but he thinks I won't have this problem again. Sorry, but they said they have no idea what caused the noise, but after they torgued everything I can't get it to make the noise under any situation. Take it to Acura and have them torque everything and your problem will be solved. I think I caused the problem doing some fun runs at a auto-x where I did some extreme drifting, and the R hooked so hard that my helmet hit the drivers window a few times, because after that my door didn't open or close the same for a few days, then it went back to normal.
P.S. https://honda-tech.com/zerothread?id=204605
[Modified by 01PYTypeR#1140, 11:40 PM 6/20/2002]
Old Jun 20, 2002 | 10:12 PM
NWPNOMORE's Avatar
Banned
Default Re: Can anyone help me diagnose this problem? (01PYTypeR#1140)
thanks man, i guess i'm having a similar problem like you had. It started after I took my car to the track.
Old Jun 20, 2002 | 10:22 PM
jonas's Avatar
i had a similar problem. it took me a while to figure out a SIMPLE solution.
i swear it was comming from the left front wheel..
it ended up being my right wheel running on 2 lug nuts
thieves probably
AutoXer
Dec 22, 2010 02:49 PM
ritz7
11
Dec 19, 2010 03:22 PM
thavarin
Jul 2, 2007 02:55 PM
uno-cam
19
Jan 23, 2005 10:20 AM
Crxer
Aug 23, 2002 08:10 PM
