Pulled code 65: suggestions?
Old Oct 10, 2007 | 12:47 PM
JasinC19's Avatar
Default Pulled code 65 on my 2000 Si: suggestions?
-=65 Secondary oxygen sensor heater wire (black wires)=-
What are heater wires? Should I replaced the whole o2 sensor and connector? Or are the heater wires located somewhere else?
Thanks
Jason
Old Oct 10, 2007 | 01:10 PM
Jason-'s Avatar
I believe it is just part of the normal secondary o2. Try replacing it, and keep the packing nice incase that was not your problem.
I'm not sure though.. lol
-Jason
Old Oct 11, 2007 | 07:27 AM
JasinC19's Avatar
Default Re: (Jason-)
The secondary o2 sensor would mean the downstream one, aka post catalytic converter?
Jason
Old Oct 11, 2007 | 08:36 AM
z211's Avatar
Default Re: (JasinC19)
got the same code 65 for the last month or so... you shouldn't worried about it... it simply mean that your o2 sensor will take a longer time to get to the right temperature for a good reading... and your car may be less economic on gas...
obd2 cars tend to get that kind of bad reading from the o2 sensors... if you really want to replace it... it'll cost you ± 150$ for the sensor and the whole plug/wires assembly...
Old Oct 11, 2007 | 09:47 AM
EE_Chris's Avatar
Default Re: (z211)
Any other codes we "shouldn't worry about" besides 65?
Unplug the O2 sensor (post-cat) from the engine harness. Using a meter, measure the resistance between the two black wires. It should be 15-40ohms. If it's not, replace it (NTK/NGK, Denso....do not use Bosch, Walker or any 'universal' O2 sensor that requires wiring).
kcrxxx
Aug 13, 2007 05:10 PM
98exturd
Aug 12, 2007 02:31 PM
oh_lee_allen
Apr 29, 2007 01:25 PM
ElectronMan
Jun 30, 2002 11:28 AM
