i need some 89-91 si lca's
Old Jun 19, 2002 | 07:48 PM
uneekcrx's Avatar
Default i need some 89-91 si lca's
i'm trying to find some 89-91 lower control arms so i can put some new aftermarket shocks on my crx.....if anyone knows where i can get some please post
Old Jun 19, 2002 | 08:23 PM
spettinger's Avatar
Default Re: i need some 89-91 si lca's (uneekcrx)
do you have an 88 and need different ones? the 88's are actually better than later years.
Old Jun 20, 2002 | 04:33 AM
uneekcrx's Avatar
Default Re: i need some 89-91 si lca's (wreckedhatch)
yea i do have the 88 ones....but i cannot find any adjustable aftermatket shocks for the rear so i need to change them out.......
Old Jun 20, 2002 | 06:41 AM
Dano's Avatar
I have a CRX 88 Si and i have KWB AGX adjustable that fit perfect.
In 88 there's 2 models : one with bushing and the other with fork
Take a look :
http://www.hondaautomotiveparts.com/...SHOCK+ABSORBER
If you have the model with the fork NO PROBLEMO they are the same for 89-91
Good luck
Dan
Old Jun 20, 2002 | 09:29 AM
therealciviczc's Avatar
Any junk yard should have them for a good price, but they may only want to sell you the whole rear suspension. My recomendation is to buy the whole rear suspension off of a 91 CRX Si so you get the reardisks too! You should be able to find that for around $150.
Where are you located? I can probably dig some up in my shed or off of one of my parts cars, but it would be a while because the cars are at my Dad's place which is 3 hours from here. It would be a week or 2 before I got back there to get them. Keep me in mind if you don't find them anywhere else. I'll help you out.
Old Jun 20, 2002 | 10:25 AM
EL Vap133's Avatar
get the shocks for a Type-R, the rear shocks are the same...
Old Jun 20, 2002 | 10:34 AM
uneekcrx's Avatar
Default Re: i need some 89-91 si lca's (Dan_crxsi88)
how can they be the same...? one mounts over the lca and the other mounts inside it ....kyb doesn't have a model # for the 88' rear suspension...
Old Jun 20, 2002 | 11:58 AM
Hunter's Avatar
the '88 lca's are the same as the integra type r's. the shocks mount in between it, not around it. the '88's are actually better IMO. if you ever want to get a tien or another top of the line suspension, you'll need the '88 or type r lca's. hope this helps
Skipper75
Apr 16, 2007 06:48 AM
JH4DC231
Oct 12, 2005 06:12 AM
green98civic
Mar 8, 2004 11:02 AM
rasta420
Oct 24, 2002 10:18 PM
uneekcrx
Jun 17, 2002 06:50 PM
