CRX b16 throttle bracket, Not sure which one i have...Can you identfy it??
Old Oct 10, 2007 | 10:43 AM
alscrx's Avatar
Default CRX b16 throttle bracket, Not sure which one i have...Can you identfy it??
My b16 came with a new cable mounted to the intake manifold. The b16 was in a crx previoulsy i was told. But i can't seem to get the cable slack out. When i put my finger under the cable i can easily move it up and down. See in pics how i can't pull that cable back anymore or i won't be able to tighten the lock nut. Should i change the bracket or is the cable wrong???
Modified by alscrx at 2:55 PM 10/10/2007
Old Oct 10, 2007 | 10:56 AM
alscrx's Avatar
Default Re: CRX b16 throttle bracket, Not sure which one i have...Can you identfy it?? (alscrx)
Please help out with pics of your crx b16 throttle cable and bracket
Old Oct 10, 2007 | 11:11 AM
jacoop86's Avatar
that looks like the 1st gen b16a bracket. what throttle cable are you using? if its stock, you will either need to use a 90-91 throttle cable, or rig up your bracket. i think password:jdm also sells a bracket to use the stock cable and b16a bracket.
Old Oct 10, 2007 | 11:56 AM
alscrx's Avatar
Default Re: CRX b16 throttle bracket, Not sure which one i have...Can you identfy it?? (jacoop86)
That cable came with my motor, I bought it from someone who had it in a 91 crx. Thats def not a stock cable as it is longer....But i think if i get a new bracket i am better off, Which bracket does everyone use with the teg cable???
Pretty sure i have a teg cable. But looks like stock bracket
Old Oct 10, 2007 | 12:12 PM
ludesrv's Avatar
I always ran the PR4 stuff. Worked great.
Old Oct 10, 2007 | 12:24 PM
Zaakro's Avatar
Default Re: (ludesrv)
I have the stock bracket that looks like yours and I am using an 91-93 LS cable
Old Oct 11, 2007 | 08:00 AM
alscrx's Avatar
Default Re: (Zaakro)
If your using the same bracket do you have the same slack problem??
I see your cable is a little slanted, Did you bend the bracket?
Also the motor your using has a different manifold then me, What motor is that? I know b16 from sir or xsi?
Old Oct 11, 2007 | 05:34 PM
alscrx's Avatar
Default Re: (alscrx)
BUMP for help
Old Oct 11, 2007 | 05:45 PM
eda6's Avatar
you could unbolt it, move it to the right and secure it wilth one bolt. slack would be gone. then find the right bracket or fab your own.
Old Oct 11, 2007 | 05:53 PM
alscrx's Avatar
Default Re: (eda6)
Yeah i was affaid it would come loose. Before making my own i thought i would search on here, I thought this was common but noone has a specific bracket for me to use. I am sure its the 90-93 cable but i must have the stock bracket.
ANyone know the right bracket to use on the b16 with 90-93 throttle cable??
Old Oct 11, 2007 | 06:11 PM
4GE4YA's Avatar
I am using the stock 1990 std model throttle cable with a inovative throttle bracket. Works great. Oh by the way this is also on a B16.
Old Oct 11, 2007 | 08:26 PM
alscrx's Avatar
Default Re: (4GE4YA)
So with the innovative bracket you can use your stock cable?? Not a bad idea..Does the stock cable actually reach?? Looks short
Thanks man
JayDMEK98
Mar 2, 2013 01:56 PM
Zubi
18
Sep 17, 2006 11:10 PM
Autoworks
Apr 14, 2005 05:23 PM
Autoworks
Mar 10, 2005 03:46 AM
