D16 eagle rods knotching??
Old Oct 10, 2007 | 09:38 AM
HondaEJ7's Avatar
Default D16 eagle rods knotching??
Hey guys
Im going to boosting my d16y5 at about 12-15 psi, havent decided yet
im ordering vitara pistons, normal sized
now, i know i could use LS rods or whatever, but i would rather go Eagle rods
I have heard from people and read that you need to knotch the block?
I also have heard that the newer eagle rods dont require block knotching?
can anyone confirm for me? this is a stock d16y5 motor.
thanks
Old Oct 10, 2007 | 09:45 AM
d15Beta's Avatar
the eagles we've used required notching... no big deal though.. nuthin a dremel and grinding bit cant do hehe
HTH
Old Oct 10, 2007 | 09:51 AM
HondaEJ7's Avatar
really?
so no matter what, block needs to be knotched?
how much
Old Oct 10, 2007 | 10:21 AM
ihaterust's Avatar
Default Re: (HondaEJ7)
all dseries need to ne notched for eagles
Old Oct 10, 2007 | 12:10 PM
HondaEJ7's Avatar
great.
thanks
Old Oct 10, 2007 | 03:41 PM
esteen2's Avatar
The block and main girdle need to be notched. A dremel may work but a die grinder would be much easier.
p.s. this is the all motor fourm.
Old Oct 11, 2007 | 03:47 AM
d16dcoe45's Avatar
Default Re: (S2R Honda)
I know on the a6 the main girdle does not have to be notched. I believe on the y8 and y5 that it will slightly have to be notched. Go to the Endyn website and look in the archive section, it has some good pics of what is necessary for the process of notching the bottom of each cylinder. You really aren't going to want to use a dremel, you will need a die-grinder with a long extension to do it.
Old Oct 11, 2007 | 06:40 AM
spun Vtec's Avatar
Default Re: (d16dcoe45)
The oem rods are press fit and the eagle rods are not.
LS rods have to be rebushed at the small end for the d series 19mm wristpin and the big end needs shaved to fit the journal of the d16 crank.
block needs notched for just about any aftermarket rod, Also for the ls rods.
Modified by spun Vtec at 11:15 AM 10/11/2007
Old Oct 11, 2007 | 06:45 AM
Furyof4's Avatar
Default Re: (spun Vtec)
Vitara pistons are floating pin, no machining required.
Why is this in the allmotor forum anyway?
Old Oct 11, 2007 | 06:47 AM
spun Vtec's Avatar
Default Re: (Furyof4)
Modified by spun Vtec at 11:14 AM 10/11/2007
Old Oct 11, 2007 | 06:59 AM
Furyof4's Avatar
Since when? Every Eagle Ive seen is floating pin.
This setup has been done 100 times successfully with no machining.
Old Oct 11, 2007 | 07:05 AM
spun Vtec's Avatar
I just thought the vitara pistons were like the oem piston and came stock without the clips to hold the wristpin
I Have my terminology wrong, you are right the eagle is floating.
So i take it the vitara piston can be used with floating pins and press fit pins?
Modified by spun Vtec at 11:18 AM 10/11/2007
Modified by spun Vtec at 11:22 AM 10/11/2007
Old Oct 11, 2007 | 07:16 AM
Furyof4's Avatar
Oem piston and rods have the pin pressed into the rod and it floats in the piston. So yes, vitara's will work in oem pistons because the pin is held in place by the rod. Eagle rods are floating pin, like used on all aftermarket forged pistons.
Edit: You changed your post before I could respond.
Old Oct 11, 2007 | 07:21 AM
spun Vtec's Avatar
Why the hell do they call the pin a "floating pin" when it is stationary?? thats just dumb. they should call it a "fixed pin".
The pin doesnt float. The rod floats on the pin.
Old Oct 11, 2007 | 08:13 AM
HondaEJ7's Avatar
its in all motor because i didnt know where else to put it
i have also heard about the vitara's using floating pins on the rods, but i dont understand it, until i read these posts
so the block would have to be knotched no matter what rod is used other than a d-series rod.
Old Oct 11, 2007 | 08:31 AM
Furyof4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaEJ7 &raquo;</TD></TR><TR><TD CLASS="quote">
Yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spun Vtec &raquo;</TD></TR><TR><TD CLASS="quote">So i take it the vitara piston can be used with floating pins and press fit pins?</TD></TR></TABLE>
Yes
The pin doesnt float. The rod floats on the pin.</TD></TR></TABLE>
The pin is not stationary, what gives you that idea. Its called a "floating pin" because its not fixed in either the rod or piston. The only restriction it has is the circlips in the piston that are only there to keep the pin from hitting the cylinder, it has the freedom to spin in the rod and the piston.
Old Oct 11, 2007 | 09:32 AM
spun Vtec's Avatar
Oh I thought the clips put tention on the wristpin. Makes sence now. I have had eagle rods and arias pistons for 3 years and havnt installed them yet.
Old Oct 11, 2007 | 10:04 AM
RagingAngel's Avatar
you might want to wait for fjt's new I-Beam rods that require little to no notching.
Those will definitely hold for the amt. of boost you're planning to take. Next time try the tech or FI forum...
Old Oct 11, 2007 | 02:41 PM
esteen2's Avatar
Default Re: (RagingAngel)
My girdle is notched on my a6, and I bet it didnt need to be.
vtechjunkie
Dec 7, 2008 01:00 PM
tobe1424
Feb 25, 2006 10:12 AM
brusk13
Jun 8, 2005 08:36 PM
maximedx
12
Jan 29, 2002 05:44 AM
