what cam for a daily driver
Old Oct 10, 2007 | 07:03 AM
grnaccord's Avatar
Default what cam for a daily driver
I have a z6 head on my daily driven crx so what cam would benefit me the most and what other valve train components should buy with it. I do weekend mountian runs and some drag racing( on the track of course, because streetracing is for losers)
Old Oct 10, 2007 | 07:10 AM
89efDUSTY's Avatar
Default Re: what cam for a daily driver (grnaccord)
Bisimoto? I am not to sure on cams, but if you want more power why not find it in other areas...FI. Your goals are not really stated, do you commute with this car as well as the other actvities posted? But all in all, I have only heard great things in regards to Bisimoto and D-series. If you do go that route, get a low stage cam so your car will almost ride normal and still get that extra little kick. GL
Old Oct 10, 2007 | 07:30 AM
grnaccord's Avatar
Default Re: what cam for a daily driver (89efDUSTY)
I do use this car to commute every day. so I do want something that will give me a decent amount of power and still be able to run on 87 octane. I do want to be able to run at the track and do some mountain runs and autocross also.
Old Oct 10, 2007 | 08:48 AM
Ass$nyper's Avatar
Pirate General...YARRRR
cam and 87 octane, dont go to well together.
Read up on the many cam explaintions on this site why
Old Oct 10, 2007 | 09:31 AM
ludesrv's Avatar
http://www.exospeed.com
Old Oct 10, 2007 | 09:46 AM
SIred91's Avatar
Rainman
Default Re: what cam for a daily driver (***$nyper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ***$nyper &raquo;</TD></TR><TR><TD CLASS="quote">cam and 87 octane, dont go to well together.
Read up on the many cam explaintions on this site why </TD></TR></TABLE>
Bingo........you can't mix performance and low octane gas.
Old Oct 10, 2007 | 09:59 AM
ludesrv's Avatar
Default Re: what cam for a daily driver (SIred91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">
Bingo........you can't mix performance and low octane gas.</TD></TR></TABLE>
Actually you can mix mild upgrade cams and low octane fuel, but you wouldn't make that much more power and it's always smart to run at least 89, since it's what honda recommended to use from factory (my H22 prelude was 91).
You can't mix higher compression and low octane fuel.
Old Oct 10, 2007 | 11:50 AM
Ass$nyper's Avatar
Default Re: what cam for a daily driver (ludesrv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">
You can't mix higher compression and low octane fuel.</TD></TR></TABLE> Well you can, but unless you'd rather expand on things like timing and bleeding compression due to cam sizes and the such. It's pretty much safe and simple to say cam + 87 = no go.
Really the mild upgrade cams in my eyes do better with some more timing and I'd want 91 at very least even though i'm sure you can get away with some 89.
But, if the op wants to expand on it i'm more then happy, if not we can leave it simple for him
OnlytheEnergy
Jun 12, 2010 02:40 PM
pootie.teng
Oct 2, 2007 07:03 PM
.Unknown.
33
Feb 19, 2005 05:44 PM
rcurry14
Jul 31, 2004 10:02 PM
DR.DRum
Jun 8, 2003 04:48 AM
