Code 67 Catalytic Converter
Old Oct 10, 2007 | 06:35 AM
EKSedAndy's Avatar
Default Code 67 Catalytic Converter
I'm getting Code 67, which I believe is the catalytic converter. I noticed that starting at the top of the upper O2 sensor there is a hairline crack in the exhaust manifold that runs about three or four inches long. Could this crack be causing my Code 67, or is it definitely my cat?
Old Oct 10, 2007 | 06:40 AM
pdiggitydogg's Avatar
is this on a d16y7?
Old Oct 10, 2007 | 06:42 AM
EKSedAndy's Avatar
Default Re: (pdiggitydogg)
Yes, D16Y7, 97 LX sedan.
Old Oct 10, 2007 | 06:54 AM
There was a Honda bulletin about cracked downpipes on the y7.
I cant seem to find it now..... If no one else can pull it up, the dealership can give you information about the TSB
Old Oct 10, 2007 | 06:57 AM
EKSedAndy's Avatar
Sorry, I'm a newbie, what does TSB stand for?
Old Oct 10, 2007 | 07:20 AM
EKSedAndy's Avatar
I'm thinking of using Ultra Copper gasket maker (supposedly good for exhaust manifold gaskets) to try and seal up this crack. I'd get it welded but that would mean welding my O2 sensor right in there, and since the manifold and cat look to be all one piece that would be a brutally expensive piece to replace. So if I gum some of that gasket maker on there and pull the negative off the battery to reset the code, this should tell me if the crack is my problem, correct?
Old Oct 10, 2007 | 08:06 AM
Technical service bulletin - its when a lot of people end up with the same problem, they acknowlegdge the issue.
Not quite a recall...
badbuik
Jan 30, 2012 09:17 PM
socalrocks
Aug 10, 2011 07:43 PM
danteisme
Mar 16, 2005 07:01 AM
btrim23
Mar 14, 2005 08:01 AM
Ya@inlinePRO
Apr 3, 2004 09:51 PM
