Rebuilding steering rack...
Old Oct 10, 2007 | 02:43 AM
Tysnet's Avatar
Default Rebuilding steering rack...
I have a 1990 Crx Dx and I'm rebuilding the rack and pinion. I have it all taken apart down to the pinion. I've removed the 35mm retaining ring, but it's not coming out. I have a feeling it's pressed in with a machine press. Does anyone know?
Old Oct 10, 2007 | 12:01 PM
vanrij's Avatar
Default Re: Rebuilding steering rack... (Tysnet)
Heat it up with a torch, turn it upside-down and tap it, the bearing will fall right out.
Old Oct 10, 2007 | 02:21 PM
Tyson's Avatar
it is press fit. use heat or use a bearing puller.
Old Oct 10, 2007 | 09:34 PM
Tysnet's Avatar
Default Re: Rebuilding steering rack... (Tyson)
Ok... How does a bearing puller work? And how would I put the new bearing in?
Old Oct 12, 2007 | 01:38 PM
Tysnet's Avatar
So does anyone want to tell me the rest of the procedure? Will I need a bearing press to put the new bearing in?
Old Oct 12, 2007 | 02:34 PM
vanrij's Avatar
There is no way to access the bearing from the other side and not enough room to pull the bearing out. Use heat, it works perfectly.
Old Oct 13, 2007 | 01:47 AM
Tysnet's Avatar
Default Re: Rebuilding steering rack... (vanrij)
Can I use the butane torch to put the new one in? If so, would I need to heat the bearing up as well as the rack housing or just the rack housing?
Old Nov 1, 2007 | 07:35 PM
vanrij's Avatar
You just heat the housing. Hopefully you already got it in
Old Nov 4, 2007 | 09:04 PM
Tysnet's Avatar
Ya much further now! Actually all done rebuilding the rack and replacing all my front end suspension bushings. Just need to put my rack in and adjust it. My manual isn't very clear on how I should adjust the guide screw though... It say's to tighten until the spring compresses, but does that mean until it's fully, partially, or slightly compressed? And then it say's to back off 40-60 degrees, is this right? I've seen 3 or 4 different attribute's, but none the one I have in my manual. Anybody know for a 90 crx?
Old Nov 4, 2007 | 10:31 PM
Tyson's Avatar
its really trial and error. do it as the manual says, tighten it by hand until it bottoms out and then back it off as it says. but really, i guarantee you that youll end up redoing it after the first run. it will affect steering resistance feel. adjust until youre happy. no big deal.
enjoy.
Old Nov 4, 2007 | 11:08 PM
Tysnet's Avatar
Alright, hey thanks a lot man! It's nice to have somewhere to come for this kind of stuff.
Old Nov 7, 2007 | 03:27 PM
Tysnet's Avatar
Ok this will be my very last question about this subject. So when I disconnected the inner tie-rods from the outer tie-rods I didn't mark there previous positions. Should I just guess and make sure that each side is screwed on at the same length? Or is there more to it?
Old Nov 7, 2007 | 03:29 PM
Tyson's Avatar
eyball it, test drive then adjust and then go immediately to the alignment shop.
use a straight edge or something to help see the ROUGH angle. but you cannot get any accurate measurements without some real measurement tools like longacre toe plates.
dont even think about driving anywhere else other than the alignment shop.
parahelium
Transmission & Drivetrain
Jun 8, 2017 10:46 AM
Hellahflush
Mar 27, 2015 05:15 PM
cj90si
Honda Motorcycles
Oct 3, 2011 04:22 PM
bobfuller30004
Classic Hondas
Apr 30, 2008 10:02 PM
