Custom D series transmission to B series motor adapters.. say what?!
Old Oct 9, 2007 | 11:21 PM
Neptronix's Avatar
Default Custom D series transmission to B series motor adapters.. say what?!
So.. i found a guy locally who can install a B18B swap into my civic. He started talking about keeping my D transmission because it's light and would be good for accelleration.. he says a buddy of his creates custom adapters.. wtf? i've been on this messageboard for a while and haven't heard anything like this plus it seems technically far fetched.. I'm starting to question his integrity.
Is this a total load of bull or what?
Old Oct 10, 2007 | 08:41 AM
slomofo's Avatar
GDD Member
Search is your friend.
https://honda-tech.com/zerothread?id=1720824
Old Oct 10, 2007 | 08:47 AM
IT GUY's Avatar
Default Re: (slomofo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slomofo &raquo;</TD></TR><TR><TD CLASS="quote">Search is your friend.
the OP is talking about b series engine with d transmission.
you posted a link about a d series engine with a b series transmission...
Old Oct 10, 2007 | 08:57 AM
slomofo's Avatar
GDD Member
Damn it! I didn't read the link, just posted the first thing that came up that had more than one page.
Old Oct 10, 2007 | 09:02 AM
IT GUY's Avatar
ah, at least you put forth some effort...
I've never heard anything about a b engine with a d tranny.
I know Bisi used to run a d tranny with a f series accord motor way back when. Haven't been able to find a thread yet though
Old Oct 10, 2007 | 07:14 PM
K2e2vin's Avatar
He still does if I recall correctly. He may sell them on his site.
Old Oct 10, 2007 | 07:20 PM
Neptronix's Avatar
Default Re: (K2e2vin)
d series with a b motor.. weird. now that doesn't make any sense.
no no.. other way around :}
Old Oct 10, 2007 | 07:24 PM
K2e2vin's Avatar
Well, the B-series do have better gear ratios(hell, the LS has a shorter final drive than the USDM D-series).
Bisi runs custom gear ratios IIRC, so that would be an exception.
Old Oct 10, 2007 | 09:44 PM
Richard...'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K2e2vin &raquo;</TD></TR><TR><TD CLASS="quote">Well, the B-series do have better gear ratios(hell, the LS has a shorter final drive than the USDM D-series).
Bisi runs custom gear ratios IIRC, so that would be an exception.</TD></TR></TABLE>
well that can all be fixed with custom gearing from mfactory for example and IF you new anything about the SOHC you would know it has been seriously DE-TUNED!
get your gearing sorted out before you do anything with your engine that alone can make or break a setup!
Oh and the reason bisi uses the D trans is because it is superior not only because it is lighter but also because the syncro’s are much stronger the only thing that holds the d trans back is the bullshit gearing Honda gave it which can be fixed!
Old Oct 10, 2007 | 09:47 PM
kaiba's Avatar
https://honda-tech.com/zerothread?id=1720824</TD></TR></TABLE>
I never know bout this.
Old Oct 10, 2007 | 10:00 PM
K2e2vin's Avatar
Default Re: (Richard...)
I wouldn't say they were detuned; but rather never tuned to make use of the potential they have; they're all pretty much biased towards fuel economy(the chassis they come in is a dead giveaway).
I think the whole reason Bisi started using D-series transmission is because of the weight and availability(they interviewed him in Honda Tuning). His transmission is also using dog clutch instead of synchronizers; which are much stronger but harder to drive on the street.
I'm just saying, out of the box, a B-series has much better ratios(especially the B16 and ITR transmissions) and the gear sets themselves(I'm speculating since I don't know for sure) are a little beefier in the B-series. When you go aftermarket, of course parts should be stronger/better.
I know a little something about doing transmission first. One of my first mods after D15B VTEC swap was a DOHC ZC transmission with CRX Si countershaft and differential out of a 92-95 EX gearbox.
Old Oct 11, 2007 | 09:01 AM
Bisimoto's Avatar
Actually, I run factory 1-5 gears mated to a dog rings by Houseman (www.racegearbox.com).
The only after market gear I have is the final drive set.
BTW, I ran bone stock D syncros until 2004.
Old Oct 11, 2007 | 11:24 AM
Neptronix's Avatar
hmm.. okay. but back on topic.. d series transmission mated to a b series motor.. possible?
I've got an EX tranny in good shape so keeping it isn't too far fetched.
Old Oct 11, 2007 | 12:09 PM
IT GUY's Avatar
Default Re: (Neptronix)
you said you knew someone who made adapters
so.... if that's true isn't it possible?
you can do anything with enough time/money/resources..
It's seems like the knowledgeable parties in here have given you info on gearing, strength, weight.. alot of good info that should help you decide whether or not you really wanna do something like that. Just up to you to decide whether it's worth it, whether you trust the guy doing the swap, etc..
GL
Old Oct 12, 2007 | 07:31 AM
jdm_titan's Avatar
Default Re: Custom D series transmission to B series motor adapters.. say what?! (Neptronix)
well there was a guy who build a thread and mated a b series trans to a h22
Old Oct 12, 2007 | 08:01 AM
IT GUY's Avatar
Default Re: Custom D series transmission to B series motor adapters.. say what?! (jdm_titan)
H2B is what they call it. I think evolution makes the kit.
Old Oct 13, 2007 | 06:11 AM
gibsanez's Avatar
Default Re: Custom D series transmission to B series motor adapters.. say what?! (IT GUY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IT GUY &raquo;</TD></TR><TR><TD CLASS="quote">H2B is what they call it. I think evolution makes the kit.</TD></TR></TABLE>
And QSD
Old Oct 18, 2007 | 09:55 PM
McDonagh's Avatar
im interested, where theres a will theres a way someone aught to know
leadfoottyler
Jan 14, 2013 09:17 PM
unrealwrc
Oct 24, 2008 03:25 PM
dj4monie
Feb 22, 2008 05:25 AM
QBANBOY407
Honda Civic (2001 - 2005)
Dec 25, 2007 04:35 PM
DTLandLTD
Jul 24, 2005 01:30 PM
