Searched long and far before i posted this thread. Engine help
How do i disassemble an engine? what i mean is once i take the valve cover off how to i begin to take the head off of the block?
Take the header and PS off, then the VC, then the timing belt and that stuff, then the cam caps/cams, then the head bolts will be underneath that. You can leave the intake manifold on, just make sure all the wires/vac hoses/fuel lines have been removed before you try to lift it off the block.
And yes get a helms, a real one!!
I took apart an engine. Nothing super complicated. Just a bunch of losening bolts. Make sure you have at least a 1/4 in drive and a good long rachet. Also, an extension would help. You need A LOT of leverage to even get the head studs to budge. And MAKE SURE YOU LABEL EVERYTHING!
thanks guys. i actually own a helms manual. i was just hoping someone had made a write up i couldn't find. The engine is already out of the car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prudz_lude »</TD></TR><TR><TD CLASS="quote"> thanks guys. i actually own a helms manual. i was just hoping someone had made a write up i couldn't find. The engine is already out of the car.</TD></TR></TABLE>
The write up is in the Helms! It shows you every step you need to take! Even with pictures!
Just to beat this into your head.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 »</TD></TR><TR><TD CLASS="quote">Use teh helms.</TD></TR></TABLE>
hahahaha guys this isn't even for me, this is for a friend. he just wanted you guys to give some insight in what to do. I am sure the helms is more than enough.
EG2 SiR
Aug 31, 2003 09:03 PM
