Got the motor an tranny out...
Old Oct 9, 2007 | 10:24 PM
DrivinVtec's Avatar
Default Got the motor an tranny out...
an everything is getting replace when it comes to the motor. what should i replace in the tranny?
- throw out bearing-done
- clutch,FW ect- done
Maybe pilot bearing. Anything else?
Old Oct 9, 2007 | 10:27 PM
AaronW's Avatar
Default Re: Got the motor an tranny out... (DrivinVtec)
Master and Slave cylinder if they weren't done recently.
Old Oct 9, 2007 | 10:35 PM
DrivinVtec's Avatar
Default Re: Got the motor an tranny out... (AaronW)
how much do they go for? My cars a 2001...do really need to?
Old Oct 9, 2007 | 10:40 PM
AaronW's Avatar
Uhhh, like $20 for a slave, $50 for a master. When one goes out, the other will follow shortly.
No, you don't have to, you can replace them with the motor and tranny in the car. I just figured since you're on the whole, replacing/rebuilding everything kick, you should do it.
If you've never replaced them yet, I would recommend doing it.
Old Oct 9, 2007 | 10:42 PM
DrivinVtec's Avatar
Ill look into it.
I was thinking on thing on the tranny. any seals that are easy to get to? tips/tricks ect.
Old Oct 10, 2007 | 06:09 AM
98vtec's Avatar
moderator emeritus
main seal on the block.
Old Oct 10, 2007 | 06:39 AM
DrivinVtec's Avatar
Default Re: Got the motor an tranny out... (98vtec)
thats getting done at the shop.
Old Oct 10, 2007 | 10:34 AM
mattsnooz's Avatar
i'd do your master and slave aswell
Dirt cheap, easy, and will save alot of b.s. if it fails while your out.
Old Oct 10, 2007 | 12:20 PM
REDLUDE4WS's Avatar
i don't agree at all with changing the slave and master. why would you change something that is so easy to change anytime, now, when it's probably not even leaking. you are working on a honda, not a ford or gm. if it was a domestic, i'd say, for sure, but on a 01 lude.....i'd buy lottery tickets instead...makes as much sense.
Old Oct 10, 2007 | 12:32 PM
DrivinVtec's Avatar
Default Re: Got the motor an tranny out... (REDLUDE4WS)
hahaha. I was thinking the same thing. PLus $75 is hard to come by when your dishing out $3k as it is.
Old Oct 10, 2007 | 01:00 PM
REDLUDE4WS's Avatar
exactly. man, i mean if we are talking, release bearing or main seal, like 98 vtec suggested, well of course. slave and master, you don't have to have arms like 3/8 extensions to get at these parts..lol..good luck
98EJ7Y8
Nov 9, 2011 04:52 PM
8VEYBEYB
Jul 2, 2009 06:45 AM
d'sb16a2
Oct 17, 2007 04:12 PM
ApolloSpeed
Feb 12, 2006 12:51 PM
deviant1
Feb 28, 2002 03:03 PM
