F22 -> H22A1 Swap
Old Oct 9, 2007 | 10:03 PM
4thGenLuder's Avatar
Default F22 -> H22A1 Swap
So I've recently bought a complete H22 which i will be building this winter.
The only thing I'm concerned about is the swap of the H series itself seeing as my Prelude currently has the SOCH F22.
I've looked everywhere and have found bits and pieces of information regarding this swap but not nearly what I need to know.
If I use my F series harness, what kind of modification will I have to do to it other than the o2 sensor, knock sensor, VTM and wiring up vtec.
Would I be better off swapping in the entire H series harness I have? How hard would this be?
Also again, if I use the F series harness.. what to do in relation to the dizzy? (External/Internal differences)
What other things will I need to do to make this swap work? Providing I'm sticking with the F series harness.. or even if I decide to use the H harness..
If there is a thread somewhere that I've somehow missed on the F22 to H22a1 swap, a link would be much appreciated.
Any information helps guys! Spill your guts on everything related to this swap.
Thanks in advance.
Old Oct 9, 2007 | 10:05 PM
AaronW's Avatar
Default Re: F22 -> H22A1 Swap (4thGenLuder)
You're going to need the ECU from the h22 as well.
Old Oct 9, 2007 | 10:11 PM
I'll be using a P28 with S300
And I'm just going to use the H series engine harness to make life a hell of a lot more simple for me. No splicing/ Pin adding required.
Modified by 4thGenLuder at 11:34 PM 10/9/2007
BoostAndBoobs
Jul 12, 2016 04:04 PM
Alexpbnj
Jul 25, 2010 10:07 AM
Greendropped
Nov 18, 2008 01:20 PM
ezza
Jun 15, 2008 02:24 PM
