Y8 Vtec Pressure sensor questions...
Old Oct 9, 2007 | 08:37 PM
Ahknodd's Avatar
Default Y8 Vtec Pressure sensor questions...
Hopefully this forum will be more helpful...
I have a d16y8 head I'm putting on my d15 and my vtec oil pressure sensor is broken. I'd like not to have to spend more money so Im wondering if I can bypass the sensor and not use it at all?
Has anyone done this with the y8? I've heard of people with JDM b motors needing to do this when using the USDM ECUs, so I would think it would work the same way, but can anyone confirm this for me? Please I really need help on this.
Thanks!
Old Oct 10, 2007 | 02:23 PM
Ahknodd's Avatar
Default Re: Y8 Vtec Pressure sensor questions... (Ahknodd)
Help me please!
Old Oct 10, 2007 | 10:13 PM
hotroddb8r's Avatar
just get a jdm ecu, cuz there is no way you can bypass that sensor, what car are you doing tha swap?
Old Oct 11, 2007 | 04:16 PM
Ahknodd's Avatar
Default Re: Y8 Vtec Pressure sensor questions... (hotroddb8r)
Is there a JDM p28? I'm putting the y8 head on my D15 in my 91 Civic hatch.
Old Oct 11, 2007 | 05:30 PM
sicones's Avatar
yea you bypass it the exact same way people do when they use JDM motors, tap the pressure switch signal into the VTEC output
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotroddb8r &raquo;</TD></TR><TR><TD CLASS="quote">just get a jdm ecu, cuz there is no way you can bypass that sensor, what car are you doing tha swap?</TD></TR></TABLE>
you ******* newbs are getting worse and worse
edit: your better off buying a new pressure switch for ~$20 and fix the problem instead of just covering it up
Old Oct 11, 2007 | 07:24 PM
Ahknodd's Avatar
Default Re: Y8 Vtec Pressure sensor questions... (sicones)
Thanks for the help... finally a good strait answer!
I don't want to cover it up, but the sensor I have is broke and I haven't been able to find a cheap sensor and plug for the life of me. I really don't want to spend 50 bucks for either, so I was looking for a way to make this all work. I know it's just a saftey anyway.
But again, thanks.
Ahknodd
Oct 12, 2007 06:52 AM
Jakester9500
Jan 15, 2007 08:23 PM
v8killa91
Jul 26, 2006 03:34 AM
