Replace a good headgasket?
Old Oct 9, 2007 | 08:17 PM
peanut butter's Avatar
Default Replace a good headgasket?
I have the head off of my d16a6 right now that has a metal y8 headgasket on it. Now I have the head off because I'm going to replace the rings but do I need to replace the headgasket also if it wasn't leaking?
Old Oct 9, 2007 | 08:39 PM
KURUPTinc's Avatar
Default Re: Replace a good headgasket? (peanut butter)
Replace the gasket trust me once you have the head off you want to replace it. I've never came across a reusable headgasket. They are not that expensive.
Old Oct 10, 2007 | 01:28 AM
24TEN's Avatar
PHANTOM MENACE
Default Re: Replace a good headgasket? (KURUPTinc)
I have heard you can reuse metal headgaskets if you respray it with copper spray. I haven't done it myself though, and if you already have the motor apart, it's best to replace anything/everything you can while it's open. The good thing is, whether or not you can reuse the old metal one, a new one is just under $40 or so at the dealer. Unless a good majority of people say you can reuse it (based on their own personal experience) play it safe and get a new one.
Old Oct 10, 2007 | 03:49 PM
Default Re: Replace a good headgasket? (24TEN)
I probably will replace the headgasket I just really didn't want to because I just bought a headgasket for this thing not two weeks ago before I figured out the true problem.
Any other opinions?
Old Oct 10, 2007 | 04:29 PM
The_Undertaker's Avatar
75.168.105.221
I used my old mls headgasket when i removed it had less than 1000 miles and wanted to replace the valves and it works with no major leaks. 3 layer oem gasket was used.
Old Oct 10, 2007 | 05:01 PM
jdmboyef9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 24TEN &raquo;</TD></TR><TR><TD CLASS="quote">I have heard you can reuse metal headgaskets if you respray it with copper spray. I haven't done it myself though, and if you already have the motor apart, it's best to replace anything/everything you can while it's open. The good thing is, whether or not you can reuse the old metal one, a new one is just under $40 or so at the dealer. Unless a good majority of people say you can reuse it (based on their own personal experience) play it safe and get a new one.</TD></TR></TABLE>
Do not do this!!! Some of the performance shops around here used to spray that copper coating on used headgaskets to reuse them. The copper ended up getting into the cooling system and would burn up the water pumps.
Headgaskets have a crush seal that even if you torque it down, take it off and torque it again without running the motor, is no good after being fully torqued.
Old Oct 10, 2007 | 06:46 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: Replace a good headgasket? (jdmboyef9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmboyef9 &raquo;</TD></TR><TR><TD CLASS="quote">
Headgaskets have a crush seal...</TD></TR></TABLE>
Good point As stated, luckily a new metal OEM head gasket doesn't cost much.
Old Oct 10, 2007 | 06:56 PM
.Grimace's Avatar
footwork mastery
Default Re: (The_Undertaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The_Undertaker &raquo;</TD></TR><TR><TD CLASS="quote">I used my old mls headgasket when i removed it had less than 1000 miles and wanted to replace the valves and it works with no major leaks. 3 layer oem gasket was used.</TD></TR></TABLE>
don't listen to his advice, he probably got this off of his alldata
Old Oct 10, 2007 | 07:29 PM
bigluelok's Avatar
i would because when you torque the head down it might not seal 100% because when you first torque it down some sealentcomes out and closes the gaps but thats just me some people on here have used the same gasket and it worked for them so its up to you
WTB AUTO EK
Jan 14, 2006 10:21 AM
Cuong-nutz
Dec 21, 2005 05:16 PM
90LSpimpin
Oct 12, 2004 09:31 PM
juicedricer
May 26, 2003 11:10 PM
Westrock2000
Sep 23, 2002 03:08 PM
