How do u Adjust the clutch pedal?
I just replaced my clutch master cylinder because it was leaking a little bit,and bled the new one several times and it still dosent act like it is engaging all the way.My pedal has like an inch of play before it engages the clutch....the clutch is fairly new,and there is no air in the lines......so its definately the pedal adjustment.Does anybody know how to do this?I know u need a little play,but not an inch....thanks in advance to any helpfull replies.
you're gonna have to pop the lock pin from the fork to the pedal and there is adjusting i believe to be just behind the fork on the piston. I forget which way lengthens/shortens play
There is a 12mm nut behind the fork on the master cylinder rod. Loosen that nut and then turn the rod into the master cylinder (counter-clockwise) to bring engagement down and clockwise to bring the engagement up. I think that's the right directions, if I'm mistaken someone correct me please.
Thanks that is just what I needed.....and so u know I did search,just didnt have it worded the same,so it didnt turn up.But that works out perfect.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcivicracer89 »</TD></TR><TR><TD CLASS="quote">gonna have to try this</TD></TR></TABLE>
lol this isn't a blog.
gooblinn258
Jan 18, 2014 05:02 PM
krysted9354
Dec 30, 2008 09:19 PM
