tps sensor help
Old Oct 9, 2007 | 06:05 PM
traxxasx's Avatar
Default tps sensor help
Ive got a b16, its throwing the tps CEL.
I changed it but still have it.
So i tested it .5v closed, and 4.5-5v full throttle.
So i know it works, but i still get a code-7 and a high idle.
Any suggestions on what to look for to fix it.
Old Oct 9, 2007 | 06:39 PM
alscrx's Avatar
Default Re: tps sensor help (traxxasx)
Did you reset the ecu after adjusting it??
If you have a high idle that is steady turn down your screw!
Old Oct 9, 2007 | 07:09 PM
traxxasx's Avatar
Default Re: tps sensor help (alscrx)
Yes i reset the ecu tested the tps everything, it still throws the damn code, on the dash and ecu led..
My screw is all the way it the lowest idle for the tb and it sits at 2.2k, its really anooying and hard to start my car. It idles at 3k but after the fast idle goes down (after it warms up) it sits at 2.2k. Really loud and annoying and wasting gas!
My vacuum lines are all correct.
I have no leaks....Any ideas?
Old Oct 10, 2007 | 12:08 PM
traxxasx's Avatar
up
Old Oct 10, 2007 | 12:10 PM
ludesrv's Avatar
FITV could be jammed in the open, causing a high idle. Mine was intermitant, cause idle to slowly go from 750 to 2000rpm and back.
Old Oct 10, 2007 | 12:57 PM
traxxasx's Avatar
Default Re: (ludesrv)
i doubt that is because when my car hits the half way warm up mark on temp gauge, i can clearly hear the car idle down a bit. but still way to high.
Old Oct 11, 2007 | 12:50 PM
traxxasx's Avatar
up
1990si
Dec 11, 2006 10:01 AM
JSR
May 17, 2006 10:27 PM
mafay2
Jul 13, 2005 11:52 AM
maxpsi
Jan 16, 2003 12:51 PM
