no start, no codes
Old Jun 19, 2002 | 06:32 PM
Bgladfelter's Avatar
Default no start, no codes
ok, my car isn't starting at all now.
Heres what its been doing up till now:
When pushing the gas more than a cm the RPMs would drop quickly. the more I pushed the worse it would get till the pt where it would hit zero and stall if I didn't let completely off the gas.
Then it started stalling while cruising. I'd be driving along and then I'd see my motor slowing down and shutting off.
Now my car might start for 5 sec, but normally it won't start.
Heres what I've done/checked:
Coil (from the Helms)
replaced igniter
checked fuel pump for Voltage. I can also smell the gas after trying to start it.
checked spark, not really any. it misses badly.
Changed ECUs
checked my CAT for any clogging.
my plugs were black and I've only had the ZC in for about 2-3 months.
but it doesn't seem to be sparking b/c it won't turn over.
Does anybody have any suggestions on what might be wrong or should I just take it in to the Honda place? It also blew the number 14 fuse (thats when it started not running).
please help. I've been trying to fix this problem for almost 2 weeks (the dropping of power) and now its to the point where it won't start.
Any suggestions at all are worth it. I have the day off tommorrow and would like to get everything possible done.
Have fun at N8 for those lucky guys who get to go.
Brian G.
It kind of sounds like RCWDrums problem
Old Jun 19, 2002 | 06:55 PM
USDM 4G VTEC's Avatar
Default Re: no start, no codes (Bgladfelter)
if sparks plugs are wet and smell like gas u got inyection of gas
check for pressure in gas lines
check if u got spark, by holding a spark plug into the header while cranking
change fuseand see if it blows it again(BTW what fuse is it?)
check main relay
also since u did a ZC into a 3G civic can u give me alittle help in my topic.. my cousin wants to put one on e 84-87 civic or crx and wants to know what to do and what to transplant.. peace
Old Jun 19, 2002 | 06:59 PM
Default Re: no start, no codes (JDM EF9)
The black top ones I've been told won't work and I see why. My little brother has a 86 CRX Si and the mounts are not close enough to even try. SCC did a whole article on the integra motor into a first gen CRX/3rd gen civic.
I think I'm going to check that tommorrow.
Old Jun 20, 2002 | 07:48 AM
thisbravenew_world
May 24, 2008 02:52 AM
BlueLude84
Jan 13, 2007 10:11 PM
Tr0LL
Nov 5, 2006 12:20 PM
StraightCivic
Mar 24, 2006 06:37 PM
93egsi
11
Jun 18, 2004 05:37 AM
