1993 Honda Del Sol
Old Oct 9, 2007 | 05:20 PM
arayam1624's Avatar
Default 1993 Honda Del Sol
I have a 93 del sol that when i turn it on white smoke comes out of the exhaust. It does have a rebuild engine. Block is a D16Z6 with a D16Y8 Head. Any suggestion what the problem might be please let me know.
Thanks
Milton
Old Oct 9, 2007 | 05:52 PM
B164DRDL's Avatar
Default Re: 1993 Honda Del Sol (arayam1624)
usually when it smokes when you crank it, its the valve stem seals. Where they replaced when engine was rebuilt?
Old Oct 9, 2007 | 06:01 PM
Boost_V's Avatar
Default Re: 1993 Honda Del Sol (B164DRDL)
what do you mean when you say rebuilt? Like, an actually full tear down or build up or simply replacing a few parts?
Old Oct 9, 2007 | 07:07 PM
arayam1624's Avatar
it was a full tear down engine everything was new. The only thing i left there was the pistons and everything else was changed
Old Oct 9, 2007 | 07:29 PM
WhiteOnRice's Avatar
Sounds stupid but you didn't reuse the head studs did you?
Old Oct 10, 2007 | 07:21 PM
arayam1624's Avatar
no everything is new
Old Oct 11, 2007 | 05:34 AM
michael123's Avatar
it might be one of the piston rings bro, or the head lost compression. check ur compression...
Token_Tay
Sep 30, 2013 10:55 AM
Detroit SOL
Jul 6, 2010 02:02 PM
b33p
Feb 13, 2008 05:22 PM
LoNgHoRn
Sep 30, 2006 02:28 PM
