new intake
Old Oct 9, 2007 | 04:30 PM
patrickstar's Avatar
Default new intake
im installing a new short ram intake into my 90 civic dx. is there any specific way i should take out the original one?
Old Oct 9, 2007 | 04:33 PM
CRX Toad's Avatar
Default Re: new intake (patrickstar)
Nope, just start unbolting and it will come out. What kind of motor do you have?
Old Oct 9, 2007 | 04:51 PM
i really dont know -_- haha. its the stock motor. all it says is 16 valve. would you know what it is?
Old Oct 9, 2007 | 04:53 PM
thesmogman's Avatar
Just make sure the metal on the intake does not touch the batteries positive terminal.
Old Oct 9, 2007 | 05:09 PM
Default Re: new intake (thesmogman)
thanks!
Old Oct 9, 2007 | 05:40 PM
what is this thing? and how will i remove it because it is connected to the intake.
Old Oct 9, 2007 | 05:52 PM
DenzComp's Avatar
I'm not 100% sure...it's a vent for the head. Your intake should have a hose to connect to the head from the intake.
Old Oct 9, 2007 | 05:53 PM
prettylew's Avatar
how do u remove that hose? r u serious? take off the clamp, then pull out hose.
Old Oct 9, 2007 | 06:01 PM
Default Re: (prettylew)
oh ok thanks!
Old Oct 9, 2007 | 06:24 PM
Fuzzy Rhubarb's Avatar
Default Re: (patrickstar)
The absolute next thing you should do would be to replace the DPFI with the MPFI.
Old Oct 9, 2007 | 06:43 PM
sheezy's Avatar
Default Re: (Fuzzy Rhubarb)
whats the difference? and do you need to reset the ECU after installing a new intake system?
Old Oct 9, 2007 | 06:45 PM
.Grimace's Avatar
footwork mastery
Default Re: (sheezy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sheezy &raquo;</TD></TR><TR><TD CLASS="quote">whats the difference? and do you need to reset the ECU after installing a new intake system?</TD></TR></TABLE>
shouldnt have to.
Old Oct 9, 2007 | 06:55 PM
sheezy's Avatar
Default Re: (.Grimace)
i hear resetting the ECU after adding mods on the engine will get the best of the mods power?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sheezy &raquo;</TD></TR><TR><TD CLASS="quote">whats the difference?</TD></TR></TABLE>
ALOT. Try to imagine the gains when you replace a small diameter TB, one injector and the secondary with a larger TB, and FOUR injectors. Each cylinder gets a more precisely metered amount of fuel. Gains of over 10 HP are common. With an engine rated only for 92 HP, you can definitely feel improvement. I'd reset it for the hell of it. Why not?
Old Oct 9, 2007 | 07:14 PM
sheezy's Avatar
ooooh! very useful. thanks!
Old Oct 9, 2007 | 07:24 PM
.Grimace's Avatar
footwork mastery
you could but i mean come on its an intake on a stock dpfi car. maybe 1 hp if you're lucky? its not adding much if anything.
Old Oct 9, 2007 | 07:37 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Grimace &raquo;</TD></TR><TR><TD CLASS="quote">you could but i mean come on its an intake on a stock dpfi car. maybe 1 hp if you're lucky? its not adding much if anything.</TD></TR></TABLE>
I meant switching over to MPFI. THAT will do something.
Old Oct 9, 2007 | 07:40 PM
.Grimace's Avatar
footwork mastery
oh yea of course i got that. i meant the whole resesting ecu for best results.
Old Oct 9, 2007 | 07:42 PM
Ohhh *slaps self*
Old Oct 9, 2007 | 07:46 PM
Jonknee's Avatar
I remember when i did the mpfi swap on my car, i was so happy. haahah
woodenchef
10
Dec 29, 2010 08:25 PM
07SIcpe
Honda Civic (2006 - 2015)
Aug 24, 2008 09:48 AM
rbizzell30
Jun 13, 2008 03:06 PM
95-Accord-EX
Jun 4, 2007 05:56 AM
cilvia
May 20, 2007 10:14 PM
