loud clunk noise!?
Old Oct 9, 2007 | 04:04 PM
foowitdaredek's Avatar
Default loud clunk noise!?
so today i was backing up out of my garage adn i go to press the brake and i heard like a clunk noise its happend a few times already...anybody know what it could be?
Old Oct 10, 2007 | 04:48 AM
Iwanttogofaster's Avatar
Default Re: loud clunk noise!? (foowitdaredek)
Could possibly be many things,
Does it only happen in reverse? Does it happen after car has been standing a while or whilst driving? Some more information would be helpful.
Phil
Old Oct 10, 2007 | 05:12 AM
AWD Terror's Avatar
Default Re: loud clunk noise!? (Iwanttogofaster)
Not nearly enough information to give you a good answer.
Here's a guess...You put an aftermarket exhaust on, and it's too close to the floor. When you put it in reverse, the engine shifts and the exhaust touches the floor, making a rattle sound.
Old Oct 10, 2007 | 09:42 AM
yeah, it only happens in reverse.
Old Oct 10, 2007 | 10:31 AM
AWD Terror's Avatar
Default Re: (foowitdaredek)
What is your car? Year/Model?
Auto/Stick?
Performance/Upgraded Exhaust?
Only when you hit the brakes in reverse, right?
Old Oct 10, 2007 | 11:31 AM
Could be worn retainer spring(s) maybe in your calipers so your pads move a little, may be your engine rocking and catching something. A bit more info would be good though
Old Oct 10, 2007 | 06:21 PM
Default Re: (AWD Terror)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AWD Terror &raquo;</TD></TR><TR><TD CLASS="quote">What is your car? Year/Model?
Auto/Stick?
Only when you hit the brakes in reverse, right?</TD></TR></TABLE>
oops my bad... 1997 honda civic cx,stick and exhaust/header.
Old Oct 24, 2007 | 04:50 PM
it did it again today only louder!!!
Old Oct 24, 2007 | 05:17 PM
pynikal's Avatar
were is the "clunk" coming from?? under the car, side, front??? could be the motor rockin and exhaust hitting the floor pan. could be bad motor mount how many miles are on the car? swapped or stock??
Old Oct 24, 2007 | 07:15 PM
its commin from underneath the car in front, it has 200800 but i got some es motor mount inserts... could that be the problem.
Old Oct 24, 2007 | 08:48 PM
95sloweg's Avatar
check your axles and ball joints.
Old Oct 25, 2007 | 10:51 AM
pynikal's Avatar
Default Re: (95sloweg)
if you can get under the car i would look under there at everything that tourques with the motor. look at the top of the exhaust pipe, anything thats close to frame rails. and also look closely at your axles while you are under there to. you said this only happens in reverse right. see if the motor mount bushings you bought are still intact. i know some of them are kind of hoky. try that and keep us posted.
crazyhouse2011
Feb 21, 2013 02:22 PM
CivicWagonRUS
May 19, 2007 11:46 AM
ITR198
Nov 21, 2005 08:11 AM
jdmsijdm
May 3, 2004 04:01 PM
SamC
Oct 21, 2003 08:02 AM
