How can I cut ignition if my oil pressure goes to zero?
Old Oct 9, 2007 | 03:53 PM
7rrivera7's Avatar
Default How can I cut ignition if my oil pressure goes to zero?
I've heard of using a pressure switch to cut ignition when you lose oil pressure. Has anyone used/made/bought something like this? Is the extra insurance a good idea?
Old Oct 9, 2007 | 04:17 PM
d16dcoe45's Avatar
Default Re: How can I cut ignition if my oil pressure goes to zero? (7rrivera7)
http://store.summitracing.com/...w=sku
Does exactly what you want when you wire into your igntion.
Old Oct 9, 2007 | 04:19 PM
7rrivera7's Avatar
Default Re: How can I cut ignition if my oil pressure goes to zero? (d16dcoe45)
cool
Old Oct 10, 2007 | 04:54 AM
1 2 NV's Avatar
the only thing that bothers me about that is our hondas have alot higher oil pressure than domestics. my friends have low oil pressure (i forgot what pressure range). my car has more oil pressure at idle than theirs get peak. just something to think about.
Old Oct 10, 2007 | 12:02 PM
2ltrtodd's Avatar
* B A N N E D *
Default Re: How can I cut ignition if my oil pressure goes to zero? (1 2 NV)
FJO has this feature built into it. you can set it to kill your ignition if your oil or fuel or anything drops...
Old Oct 10, 2007 | 12:15 PM
IT GUY's Avatar
Default Re: How can I cut ignition if my oil pressure goes to zero? (2ltrtodd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16dcoe45 &raquo;</TD></TR><TR><TD CLASS="quote">http://store.summitracing.com/...w=sku
Does exactly what you want when you wire into your igntion.</TD></TR></TABLE>
I don't know if Summit has others, but the description on that one makes me nervous.
"Our Summit oil pressure safety switch shuts down your engine when your oil pressure drops below 7 psi, saving your engine from damage"
I think you're screwed in a honda if your oil pressure gets to 7 psi. exactly what the OP was looking for though, just need to find one with a higher pressure cut-off point
Jimster480
Feb 25, 2011 08:16 AM
steveharrmr23
Aug 7, 2008 10:52 AM
hondaeg8
Feb 3, 2004 01:05 PM
RCautoworks
Nov 22, 2003 10:01 AM
