CAR WONT REV PAST 3 GRAND!!!!
Old Oct 9, 2007 | 03:23 PM
90dxb20's Avatar
Default CAR WONT REV PAST 3 GRAND!!!!
i got a 90 crx dx with a b20z in it. i had a b16 in it and wired it myself and run fine. since i installed the b20 it will not rev past 3 grand it sounds like its on a launch control. any ideas on what could be causin this? im running a obdo ls computer in it. the ecu is throwing code 9,15,and 16. i fixed code 9 but have no clue what 15 is?
Old Oct 9, 2007 | 03:32 PM
rex89si's Avatar
Default Re: CAR WONT REV PAST 3 GRAND!!!! (90dxb20)
A friend of mine had the same problem. One of the wires he had redone on the distributor plug had came undone. I hope this helps.
Old Oct 9, 2007 | 03:37 PM
garageEF's Avatar
Default Re: CAR WONT REV PAST 3 GRAND!!!! (rex89si)
your in limp mode. solve the codes and you will be fine.
16 is injectors.
15 is ignitoion output signal.
check your wiring and try using another dizzy.
Old Oct 9, 2007 | 03:49 PM
89hatcher's Avatar
what dizzy are you using?
Old Oct 9, 2007 | 03:54 PM
jdm_titan's Avatar
it's ur wiring or ur dizzy for sure.
Old Oct 9, 2007 | 05:18 PM
cars101's Avatar
its your injectors. my friends tegg did the same exact thing and the computer told it basically not to let it rev past 3 so it wont hurt anything and is there white smoke out the back
Old Oct 9, 2007 | 06:18 PM
JiggaMcBoo's Avatar
get a new ignitor
Old Oct 9, 2007 | 07:34 PM
Max Kling's Avatar
LOL @ the top 2 posts.
What injectors are you running, do you have the resistor box still. Also what dist. are you running?
vteck1ck
Dec 27, 2009 09:16 PM
billyanderson
Oct 2, 2009 12:16 PM
2jz240z
Nov 27, 2008 08:39 AM
skiracer8148
Jan 22, 2008 07:23 AM
burnitup
Aug 14, 2006 03:32 AM
