install cams GSR
Old Oct 9, 2007 | 01:38 PM
mastakmk's Avatar
Default install cams GSR
yeah.. im installing new cams. and needed to know some quick info. all i find are threads saying.. is this the best cam or what do you think about this. but is there any precautions i should be worried about when i install these new cams? do i need to check clearance or anything. just wondering so i dont F anything up lol. thanks. just bcII's
Old Oct 9, 2007 | 02:26 PM
all-mtr-teg's Avatar
Default Re: install cams GSR (mastakmk)
What are BCII's, stock?
Old Oct 9, 2007 | 02:43 PM
1.8L_allmotormilitia's Avatar
buddyclub 2's?????? don't think buddyclub makes 2's.
Old Oct 9, 2007 | 05:03 PM
mastakmk's Avatar
Default Re: (1.8L_allmotormilitia)
sorry.. brian crower 2's. do i need to adj for valve lash?
Old Oct 9, 2007 | 05:14 PM
98vtec's Avatar
moderator emeritus
Default Re: (mastakmk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mastakmk &raquo;</TD></TR><TR><TD CLASS="quote">sorry.. brian crower 2's. do i need to adj for valve lash?</TD></TR></TABLE>
to the spec that came on the cam spec card.
please tell me you have a torque wrench and a service manual.
Old Oct 9, 2007 | 05:47 PM
mastakmk's Avatar
Default Re: (98vtec)
yes.. okay.. it says advertised duration, duration @ .050, valve lift inches and mm and, valve lash in inches.. soo im looking at these numbers. will it mention in the manual how to check these and change these measurements? thanks
Old Oct 9, 2007 | 06:26 PM
98vtec's Avatar
moderator emeritus
if you dont have a manual, much less know how to do a valve adjustment, you should seriously consider having someone who has experience in that field to do the work for you.
Old Oct 9, 2007 | 06:43 PM
check out c-speedracing.com they got several "how to" links that cover what you'll need to swap your cams. Good Luck
Old Oct 10, 2007 | 06:56 PM
mastakmk's Avatar
Default Re: (all-mtr-teg)
yeah.. i do have the book... lol this just first time doing a valve adj. and needed this link all mrt teg sent over.. thanks a lot! i have high comp pistons installed as well.. do you think i should have to clay it or no? thanks for the help.
Old Oct 25, 2007 | 07:21 PM
mastakmk's Avatar
bump.
Old Oct 26, 2007 | 07:32 AM
Claying is added insurance. Better safe than sorry, especially if the head is milled or the block is decked.
Old Oct 26, 2007 | 08:04 AM
mastakmk's Avatar
okay... the block was decked i believe. umm.. also have arp headstuds here. im reusing them from when i assembled it back in spring and all of a sudden started burning coolant. now i dont have the moly lube. is this something i can get at any local part store. or is there something i can use instead?? and about the clay. i dont really want to get into it..im prob going to use lucas assembly oil. any other recommendations? gsr motor i see ppl touqing down t0 60 some are at 70. what shall i goto? thanks. im on a diff thread they said 70.
Modified by mastakmk at 10:49 AM 10/26/2007
Old Oct 26, 2007 | 10:07 AM
I torqued my ARP head bolts to 70 ft/lb, then retorqued them after 10 heat cycles like reccomended in the instructions.
Old Oct 26, 2007 | 06:03 PM
mastakmk's Avatar
hmm... i put mine at 65lbs. shall i just retighten after 10 cyl?
Old Oct 27, 2007 | 06:46 PM
mastakmk's Avatar
Old Oct 27, 2007 | 10:06 PM
Combustion Contraption's Avatar
More importantly, how did you pull off a double post 43 minutes apart?
nokturnal_munkeeboy
16
May 5, 2007 06:48 PM
InvaderTrax
Jan 4, 2006 08:37 PM
egsi32
19
Jan 6, 2005 06:44 PM
EGRhatch
Jul 12, 2004 07:45 PM
1fastGSR
Oct 23, 2001 07:24 AM
