1993 Honda Del So. 1.6l
So I just bought it. and got a pretty good deal on it. But the previous owner was pretty dumb.
They tried to dry sand it.. It doesn't look to bad but it looks like a bad prime. lol even tho A high powered buffer will probably take it out.
Its all stock except intake and exhaust. and its Auto.
But I wanna know would it be worth it to do an engine swap and convert it to Manual.
And what engine/transmission should I swap it with and estimate how much I would need to spend?
So is it even worth it? Going through all that and then more likely having trouble with it at the end.
I'm pretty new here and wanted to ask a few questions.
convert auto to manual is time consuming and how much do u plan to spend on the swap? if u plan to do the swap..why didnt u buy a manual instead at first.
b16a complete obd1 swap..u are looking about $2000$2300
b18c swap..u are looking at $2500~$2800
h series about $2500..k series u are looking at $10000
and if u dont know how to do the swap, to have a shop do it for u will cost u somewhere betwewen $500~$700
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poopershoes »</TD></TR><TR><TD CLASS="quote">
But I wanna know would it be worth it to do an engine swap and convert it to Manual. </TD></TR></TABLE>
yes
what are you looking to spend on how much HP? cause most people will tell you to jump on the k bandwagon
IMO the roar of an H22a is fine
yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy »</TD></TR><TR><TD CLASS="quote"> why didnt u buy a manual instead at first.</TD></TR></TABLE>
probly a conveniance thing
maybe he got it for a really good deal
=P ya never know, maybe he got the car for 300$
Noooo way. I did not take no pictures. That was the kids Pictures that was on his MySpace.
And the fact that he had gay stickers on it. Which I took off.
The other car is a bretta. I wouldnt be hanging out with anyone who drove a car like that.
b20 swap it with a cheap LS tranny...looking at about 2500 if you do the work, axles, shift linkage, clutch pedal and braket, slave cylinder etc etc etc if you decide to do it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poopershoes »</TD></TR><TR><TD CLASS="quote">noob question.. Turbo-D??</TD></TR></TABLE>
I think he was suggesting you keep your existing engine (which is a D-series, if it's a 93 and still OEM) and just install a turbo.
An Auto->Manual conversion would be separate from whatever you do to your engine. You'll need additional parts to do that conversion, which is beyond what's included in a "normal" swap - shift linkage and related hardware, clutch/brake/gas pedal assembly, etc. I think there's some wiring harness differences too (automatic shifter interlock vs. clutch pedal interlock).
This is how you auto to manual a d-series. I started this how to but dint have my camera with me the day of the swap so this is as far as I got. If you wanted to swap a b-series in it then this would still apply but replace all the D parts with B parts. Pedals and all non direct motor related parts are to be collected from the manual chassis delsol.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poopershoes »</TD></TR><TR><TD CLASS="quote">The other car is a bretta. I wouldnt be hanging out with anyone who drove a car like that.</TD></TR></TABLE>HEY hey...watch it now. I'm sure that Beretta runs low 12s in the 1/4 mile. ahahahahah..j/k
ON the serious note, I have helped my cousin do an "auto-manual"/B18c swap in his Civic coupe and it was not that difficult. You need to make sure you have all your necessary parts (which includes the aftermarket "auto-->manual transmission mount") and do not ghetto-rig the wiring for the reverse and clutch pedal wiring. Also, when you put in the manual shifter, use some sheet metal to fill up the hole where the stock auto gearshift mechanism once was. I have seen some crappy work where they don't completely cover up the hole and water gets into shifter area.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boost_V »</TD></TR><TR><TD CLASS="quote">def. worth to go manual. Auto sucks in a lot of ways.</TD></TR></TABLE>
amen. ha
Thanks guys. If anything soon changes or when I know for sure what im getting ill be sure to tell you.
amen. ha
I have a 95 sol that I swapped a GSR engine into and converted it to manual. Unless you can either do it yourself or you know of a really good shop, I would say it's not worth it. I'm happy with mine now, but it took a lot of time and patience to get here.
Good luck with whatever you decide!
austinwith96civic
Sep 1, 2008 08:02 PM
stock96accordlx
Dec 1, 2007 08:14 PM
projekt-sol
Nov 11, 2007 08:12 PM
indianajones
21
Aug 29, 2005 03:25 PM
