EG Hatch - Blox rear sway bar & Exhaust clearance questions.
Old Oct 9, 2007 | 12:13 PM
EgSalad's Avatar
Default EG Hatch - Blox rear sway bar & Exhaust clearance questions.
Hey All,
Ive done a bunch of searching on this issue, and most of the topics that have come up are Comptech rear sway/tie bar combos clearances around the muffler. Ive got a Blox 21mm rear, and I dont know what the differences are in size/clearances/or fitting versus the Comptech.
Ive got a 93 Si hatch, and I was running a stock 95 GSR exhuast (modified to fit). I installed the Blox 21mm rear sway this weekend to go with the Spoon tie bar I already had, and I had to take the muffler section off so it would fit.
No biggie. I was planning on buying an aftermarket 60mm exhuast anyways. But <U>I need to find out what exhaust your running if you already have this sway bar, and if you've had issues.
I plan on buying an Ex mag, so if you've got this combo, all the better. Lemme know if it fits.</U>
If you have clearance pics, brownie points for you. Post it up.
TIA.
Old Oct 10, 2007 | 03:15 PM
EgSalad's Avatar
bump.. no one rocks the Blox rear sway?
Old Oct 10, 2007 | 03:58 PM
MurdersV8s's Avatar
Default Re: EG Hatch - Blox rear sway bar & Exhaust clearance questions. (EgSalad)
I had the same problem as you. I have the same car, but with an itr rear sway instead. I've talked to a few people who run the ex-mag and they couldn't use a sway bar. The only catbacks that I found to fit where canister types. I ended up running 2.5 piping to a factory style muffler.
If anyone knows of a noncanister catback let me know too.
Old Oct 11, 2007 | 08:10 AM
EgSalad's Avatar
cool deal.. thanks for the info. Its a start.
Bumped up.. anyone else got a Blox rear sway?
Old Oct 11, 2007 | 05:49 PM
saveacivic's Avatar
hooray
Old Oct 11, 2007 | 09:08 PM
EgSalad's Avatar
Thanks Natewick.
bumped
Old Oct 16, 2007 | 06:12 PM
saveacivic's Avatar
you could always use a folgers can with cotton inside for a muffler....
Old Dec 8, 2007 | 08:36 AM
fc3srx729's Avatar
lol...
Freemananana
Suspension & Brakes
Jul 24, 2014 10:18 AM
exare250
Suspension & Brakes
Jun 22, 2008 11:54 AM
EgSalad
Suspension & Brakes
Oct 11, 2007 05:48 PM
JD_B18CDX
11
Aug 2, 2002 09:26 AM
JeffS
May 31, 2002 08:46 AM
