AFR at idle?
Old Oct 9, 2007 | 11:06 AM
boosted91crx's Avatar
Default AFR at idle?
Hi guys, i am wondering what is a ideal AFR for a D16Z6 at idle? I am running a temporary basemap right now and i noticed at idle my wide band goes off the scale lean, while this is good for fuel economy it makes a anoying random pop out my tail pipe, i moved the AFR from off the scale to around 15.5 and the pop has all but gone away, i was wondering if its ideal to richen the idle up even more?
Old Oct 9, 2007 | 01:18 PM
The_Undertaker's Avatar
75.168.105.221
If you richen it too much you would have bad fuel mileage and lots of burning fuel and i believe the 02 sensor code will throw a code.
Old Oct 9, 2007 | 02:04 PM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
Default Re: AFR at idle? (boosted91crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted91crx &raquo;</TD></TR><TR><TD CLASS="quote">Hi guys, i am wondering what is a ideal AFR for a D16Z6 at idle? </TD></TR></TABLE>
did your stupid response answer the question at all? no. it didn't.
You can lean em out pretty good at idle, theres no load on the motor. Just tune it so its reasonably driveable and not popping all over town. also, what kind of exhaust do you have? if its pretty unmuffled that might be a big reason of why you're getting some popping sounds as well.
Old Oct 9, 2007 | 02:19 PM
jdm_titan's Avatar
it all has to do w/ timing good luck, achieving nirvana. LOL
Old Oct 9, 2007 | 02:25 PM
welfarepc's Avatar
14.7
Old Oct 9, 2007 | 09:14 PM
hondasaurusrex's Avatar
Default Re: AFR at idle? (welfarepc)
14.7:1 stoichiometric.....ideal afr
Old Oct 9, 2007 | 09:35 PM
MarlonT42's Avatar
Hahahaha...Mine runs rich all the time.
Old Oct 10, 2007 | 05:57 AM
Default Re: (MarlonT42)
rich is better than lean in my book....after all lean is mean, but lean for too long and say goodbye to a piston or two.....
Old Oct 10, 2007 | 11:57 AM
ComeOnKip's Avatar
detonation almost NEVER happens at idle, theres no load on the motor, so why give it more fuel then it needs?
Old Oct 10, 2007 | 11:58 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: (ComeOnKip)
Oh sweet god, other then Kip I see many a Need for Speed trained tuner in here
Old Oct 10, 2007 | 12:42 PM
ComeOnKip's Avatar
Default Re: (***$nyper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ***$nyper &raquo;</TD></TR><TR><TD CLASS="quote">Oh sweet god, other then Kip I see many a Need for Speed trained tuner in here </TD></TR></TABLE>
reeding iz harrd. learnding even harrderr!!
put a wideband on any stock car with a stock ecu, you'll see how lean it gets at idle. No load = min. cyl. pressure = no need for fuel.
Old Oct 10, 2007 | 03:05 PM
esteen2's Avatar
Mine idle's great around 15.7. A/F at idle and A/F under a load are two different things.
Modified by S2R Honda at 4:43 PM 10/10/2007
Old Oct 10, 2007 | 03:14 PM
welfarepc's Avatar
hey just becasue i know what his afr should be at idle doesnt mean i play NFS... thats quite ignorant!!! i play PGR 7,014 *** hat!
Old Oct 10, 2007 | 05:38 PM
ComeOnKip's Avatar
Default Re: (welfarepc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by welfarepc &raquo;</TD></TR><TR><TD CLASS="quote">hey just becasue i know what his afr should be at idle doesnt mean i play NFS... thats quite ignorant!!! i play PGR 7,014 *** hat!</TD></TR></TABLE>
yea, this coming from the guy that told me i got jdm pwned cause some poser stole a pic of a rhd interior on a crx. ***. and 14:7 is NOT what your afr should be at idle. but you go ahead you master of the dyno, you wizard of the fuel map, why not make it 11.0 everywhere for max power!?!?!!?!?!?!?!?!?
Old Oct 10, 2007 | 05:46 PM
SFlCrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ComeOnKip &raquo;</TD></TR><TR><TD CLASS="quote">
yea, this coming from the guy that told me i got jdm pwned cause some poser stole a pic of a rhd interior on a crx. ***. and 14:7 is NOT what your afr should be at idle. but you go ahead you master of the dyno, you wizard of the fuel map, why not make it 11.0 everywhere for max power!?!?!!?!?!?!?!?!? </TD></TR></TABLE>
lol my afr at idle is 15.6-16.1 when warmed up and 14.5-15.0-1 when cold according to my innovate lc1 but this is on a zc with pm6
Old Oct 10, 2007 | 05:50 PM
ComeOnKip's Avatar
a little richer when cold is nothing out of the ordinary
Old Oct 10, 2007 | 06:00 PM
SFlCrx's Avatar
yea i know if it was the same when cold and hot i would be worried. my wideband has been acting wierd lately after 5500rpms it leans out off the scale but under that it works great. any ideas
defkid999
Oct 17, 2006 10:12 AM
Hyaboosta
Jul 13, 2005 02:14 PM
JDM-EJ1
Oct 20, 2004 07:32 PM
