Where did you get this blue ground wire?
its the Type One earthing system, I think AJ should have them. Would go well with those mad tiiiiiiiiiite takata harness nO?
That's a car audio 4ga power wire with gold plated ground terminals.
There are many colors: Clear red, clear blue, clear yellow, clear black, and clear.
Now, i don't know if you guys noticed that our cars come from the factory with the ground wire connected to the valve cover bolt instead of that available threaded whole on the right (where this particular teg has its blue ground wire hooked to).
The reason is because the valve cover itself is not a good source of ground. given it is insulated from the head by the head cover gasket and the rubber seals at the bolts. When they put the ground to the head cover bolt/nut, it makes direct contact with the block head. Which is a good ground. So, I'm afraid my dear friend with the yellow head cover and the blue wire, is not doing a good ground.
That free threaded hole must be used for something else, i.e. a bracket maybe.
It's blue Lightning Audio 4 ga. wire.... the only companies i know of that make blue power wire is Lightning Audio and Phoenix Gold.
-matt
-matt
You know, those are trendy these days....
it's most likely a power wire that can be found in car audio sections of most electronic stores.
i.e. best buy, circuit city, etc...
i have a red one
[Modified by Spoon1, 6:35 AM 6/20/2002]
Reid
Not really Improper since the other grounds ground the Head SO I could actually do without the Ground pictured
I just happened to have one piece left.
Nope, Its one I made myself.
Reid
Reid
Red = constant power
Black = ground
Red/black = switched power
Blue = remote turn-on
and the rest I all forget
Pat, who likes the "red = light your *** up" philosophy
how did you manage to paint it blue!?
Paint? Paints for Wussies. We Ground up some Smurfs and Dipped the wires in it
How come some people removed the cover part that goes on top of where you can see the header. What differences does it make.
Drinker
