Honda S2000 Honda S2000
turbo s2k project..
Old Oct 8, 2007 | 05:44 PM
91jdmhatchback's Avatar
Default turbo s2k project..
well i have been working on turboing my s2k for the past few months. slowly buying/building the parts as i go, and i thought i would post up some progress so far.
manifold pics
i just threw on a t67 we had laying around for mock up on to show fitment.
we found a k&n filter that fits perfect in the little space available.
i didn't weld the manifold as it was a little more complex then i'm used to so i had one of the other guys take care of that.
i will be removing the oil pressure sensor when i install the aem.
i havn't decided yet as to what turbo i will be running. i'm stuck between a s256 and a s366, i know the 366 is quite a bit bigger but it would give me plenty of room to grow in the future.im shooting for 400 whp on the stock motor with arp's and maybe a thicker gasket, but idk.
i would have some pics of my intercoler but it has been backordered for the last few weeks but it should be here soon, hopefully haha it is 24x10x3.5 if i remember right
i'm using both the black tial 44mm wastegate and bov.My precision 1000cc injectors came in last week even though it says 950's lol
i will add some more pic's of progress as more stuff come's in and if i get off my *** and decide what turbo i want to run, i can get the dp and recurculated dump made this weekend.
Old Oct 8, 2007 | 05:47 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: turbo s2k project.. (91jdmhatchback)
any bracing of the turbo in anyway?
Old Oct 8, 2007 | 05:54 PM
JDMADD1CT's Avatar
nice project...good luck w it. just out of curiosity...cant really tell from the pics, but is the turbo too high where the hood wont be able to close?
Old Oct 8, 2007 | 05:55 PM
GDM S2K's Avatar
Default Re: turbo s2k project.. (S@nt0s)
ide DEF move the harness to the fender. that things gonna create alotta heat
Old Oct 8, 2007 | 06:02 PM
Default Re: turbo s2k project.. (GDM S2K)
santos- there will be a brace made with heim joints that will support the full weight of the turbo.
jdmaddict- no it has enough room, i have closed the hood and checked fitment on a s366 which has a larger housing then this turbo.
gdm s2k-the whole manifold,turbine side, dp, dt will be ceramic coated. also i plan on making a better heat shield then the stocker to help with the heat
Old Oct 8, 2007 | 06:12 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91jdmhatchback &raquo;</TD></TR><TR><TD CLASS="quote">santos- there will be a brace made with heim joints that will support the full weight of the turbo.
kool good luck with it...
suing AEM EMS?
Old Oct 8, 2007 | 06:22 PM
yeah aem ems, i found one pretty close for $900 brand new so i'm going to buy that. hehe
Old Oct 8, 2007 | 10:34 PM
Alleykat's Avatar
GL man.400 isnt too far away.My setup is similar.Im running a tubular topmount gt35r,1000cc injectors,Tial 44mm WG and 50mm bov.I made 400.12 with major exhaust leak we didnt know about at the time!
Old Oct 9, 2007 | 05:44 AM
trancedroller's Avatar
Default Re: (Alleykat)
Those are some crazy welds.
Old Oct 9, 2007 | 07:14 AM
Be3fJerky's Avatar
woww thats sik
Old Oct 9, 2007 | 09:06 AM
s2k diggler's Avatar
that looks good can we get a pic of the whole car!?
Old Oct 9, 2007 | 09:34 AM
Default Re: (DC2 diggler)
here are some of it from last year. (looks the same)
here it is with my old turbo coupe dd, 50 trim + d15 = FTW!!!!
this is what the engine bay looked like before i tore it apart
Old Oct 9, 2007 | 11:02 AM
papa5murf's Avatar
Your valve cover is so clean, wish mine was that clean.
Old Oct 9, 2007 | 12:04 PM
140sx's Avatar
are you going to run the oil return through the cross member? looks a little tight. nice car though
Old Oct 9, 2007 | 04:57 PM
Default Re: (140sx)
papa5murf- yeah the car is a 03' with only 20k on it. i try not to drive it but in the summer it gets alot of miles. bought it in late 05' with 6500 on it.
140sx- ha it does look deciving in these pics. there is enough room to put a 45 an fitting and angle it toward the pan. so i will be doing that.
Old Oct 9, 2007 | 06:11 PM
140sx's Avatar
ahh i see
Old Oct 9, 2007 | 07:04 PM
clean!
Old Oct 11, 2007 | 04:50 AM
deathsled's Avatar
kinda funny that you had an AUT style cooling plate but the AEM v1 that relocates the filter way down in the bumper, hehe
Old Oct 11, 2007 | 10:20 AM
140sx's Avatar
I think im going to get one of those cooling plates and run my intake into it from the turbo. Havent seen it done yet.. although im sure someone doesent have anything better to do and find one...
Old Oct 11, 2007 | 10:32 AM
papa5murf's Avatar
Default Re: (140sx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 140sx &raquo;</TD></TR><TR><TD CLASS="quote">I think im going to get one of those cooling plates and run my intake into it from the turbo. Havent seen it done yet.. although im sure someone doesent have anything better to do and find one...
Uhh yeah, stupid. Why you ask?
1. Your intercooler will more than likely block the cold air that will go through that section of the cooling plate and to your filter.
2. Who cares where you're drawing air from if you're turbo charged. It doesn't matter if your filter is getting hot or cold air, it's still going to be hot before it gets to the intercooler to be cooled.
Old Oct 11, 2007 | 05:10 PM
Default Re: (deathsled)
the garage defend cooling plate was the first thing i did to the car along with the spoon radiator cap. but the spoon badge fell off 2 weeks after i put it on so there went the bling on that.
i got the intake for like $25 so i threw in on there but i took it off as it took me out of stock class at auto-x events, and the s2000 pwns at the auto-x... haha
Old Oct 11, 2007 | 07:09 PM
140sx's Avatar
Default Re: (papa5murf)
well doing things different and makeing them work is fun . doing things the same as everyone else is boreing.
Old Oct 22, 2007 | 05:38 AM
Default Re: (140sx)
well the turbo should be here this week, finally. i went with the gt3076r .82. with the v-band outlet
the intercooler core came and if i get some time this week i will try and mock up the end tanks and see how it fits. it's a garrett core
i will get some update pics up soon.
Old Oct 22, 2007 | 05:56 AM
m R g S r's Avatar
Default Re: (91jdmhatchback)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91jdmhatchback &raquo;</TD></TR><TR><TD CLASS="quote">well the turbo should be here this week, finally. i went with the gt3076r .82. with the v-band outlet
i will get some update pics up soon. </TD></TR></TABLE>
nicee! how much did it run you? and you should have an awesome powerband with the high redline of our engine
Old Oct 22, 2007 | 07:28 AM
Francesco's Avatar
nice.
