best injectors for boosted D16z6
i have a ef civic swapping in a d16z6 boosted n would like to know wat r the best injectors for it
i currently have acura vigor injectors on my d16a6 would they b good enough
From: Where the wild things are in, NY, United States of America
wow. thats the first semi accurate thing you've had to say yet. still.... gtfo
dsms aren't the only injector you can go with, even tho everyone does backflips about them. I've always had good luck with RC engineering injectors, and they'll make damn near any size you can request.
i got a t3 t4
xtd stage 3 with flywheel,aem fuel rail wit acura vigor injectors, headers with high flow cat. 2 1/2 in. i want to get 300hp @ the wheels n need to know how to get to it the cheapes way possible but want it done right n want to drive it every day
300 wheel isn't easy in daily driver friendly d's.... you're going to have to look into an excellent flowing manifold... read up on the http://www.evans-tuning.com forums, the d's he has making over 275 usually have ultra-efficient set ups.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pitoracing24 »</TD></TR><TR><TD CLASS="quote">ok how bout gettn it to the low to mid 13s how much would it take n would it b reliable
street tires or slicks?
My friend was doing 12.6 with street tires and a slipping clutch at 10psi. It was tuned on Chrome. Bottom line is don't expect to drop in injectors and be magically perfect, Tune the setup or it will run like ***
i am running a d16zc with a t25 on 12psi with dsm 450's and it has been running 13.2 for a year on drag radials...and as a matter of fact mine are for sale if u are interested
92ehatch
Feb 8, 2007 04:47 AM
