Co2 for your tires?
Anybody have any feed back on power tank? How much will the tire pressure go up during a hot day at Buttonwillow?
http://www.powertank.com
Thinking about getting one.
-J
-J
I thought teams used 100% N2 versus CO2. If you want to do this go to a welding supply place and buy or rent a small bottle. You would then get a regulator for it and be out alot less money. The bottle would probably be a dull green so no bling bling.
The N2 is an option, but it is high pressure N2, not liquid Co2. The liquid Co2 pressure will remain constant until there is no liquid left. ie a lot more power in the same size tank.
I checked welding shops the N2 regulator runs ~$100-150. Tank runs about the same. Grand total ~$300 anyway. Tank rental run $20 per week, but no one will rent me a regulator to do a test run with. I hate to spend $300 and not get the preformance I need.
Bascially a small tank (20 CF) .28 @ 2000 psi. That is not that much than my 6 gal (.8 CF) at 125 psi. 6 gal air tank, $35 @ Walmart.
The N2 is an option. The liquid Co2 pressure will remain constant until there is no liquid left. ie a lot more power in the same size tank.
...the temperature won't effect the N2 as much as CO2 and hence less pressure gain when hot.
Question is how much will Co2 expand in comparison to air?
N2 would be great but I don't think the N2 will last much longer than my 6 Gal air tank @ 125 Psi.
I heard from one guy on a 4wd board it gets 20 tire fills out of an N2 bottle, but it is one of those 6 foot tall bottles, and he fills big tires.
gotboostedvr6
Welding / Fabrication
Nov 20, 2006 03:48 PM
ED609
Feb 6, 2006 07:59 AM
