motor build..
Old Oct 8, 2007 | 03:50 PM
soon2bdropped's Avatar
Default motor build..
1.why is it important that the rod bearing tang is always on the exhaust side is there an advantage?
2.also why is it bad to rub oil with ur finger on the rod bearing surface.. i see ton of people do it and they don't have engine failure..
3. my friend said one way to tell if u have a blown headgasket is open the radiator cap and rev the engine.. as we rev.. coolant started to shoot up really fast and splash everywhere... headgasket was blown anyways/. but how does doing that help.. what causes the coolant to shoot up as opposed to suck in..
Old Oct 8, 2007 | 03:54 PM
cartune network's Avatar
Default Re: motor build.. (soon2bdropped)
1. idunno
2. becuase by rubbing it on with ur finger u could be carrying any kind of dirt or grit with the grease which will inturn cause the bearing to wear faster by causing more friction between the bearing and crank.
3. when u rev the engine u are forcing air in and out of the combustion chamber and when the piston comes up to compress the air and fuel some of the air is escaping through the headgasket and going into your coolant passages which is what is causing the radiator to bubble.
Old Oct 8, 2007 | 04:05 PM
spun Vtec's Avatar
1: I believe it is because of the rotation of the motor.
Old Oct 9, 2007 | 04:45 PM
Default Re: motor build.. (spun Vtec)
bump bump anyone else.
so what happens if i put the bearing tang whatever side i want.. what happens.. wtf..
Old Oct 9, 2007 | 04:50 PM
spun Vtec's Avatar
You do it and let us know .
Old Oct 9, 2007 | 04:52 PM
i rather not lol...
Old Oct 9, 2007 | 05:02 PM
pinging whats the difference how do u hear it.. i advance it all the way and al i heard was the valve ticking harder...
how does pinging show up in the main or any of the engine internals parts.. what is pining and how does it show up in themotor.....
when the piston fires like halfway when its still going up and the combustion forces it down do u get the pinging sound? let me know thanks..
Old Oct 9, 2007 | 05:38 PM
Search.
Old Oct 10, 2007 | 09:41 PM
Default Re: motor build.. (cartune network)
okay anybody else that has something constructive to say thanks..
Old Oct 12, 2007 | 07:46 PM
bump to this..
Old Oct 13, 2007 | 04:16 AM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soon2bdropped &raquo;</TD></TR><TR><TD CLASS="quote">1.why is it important that the rod bearing tang is always on the exhaust side is there an advantage?</TD></TR></TABLE>
Because that's the way Honda made it? I know an individual who put an H22 together with the rods in backwards and the motor is still running
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soon2bdropped &raquo;</TD></TR><TR><TD CLASS="quote">what causes the coolant to shoot up as opposed to suck in..</TD></TR></TABLE>
Lots of pressure and heat in the cooling system.
Old Oct 14, 2007 | 09:22 AM
Default Re: motor build.. (b19coupe)
Old Oct 14, 2007 | 10:53 AM
spun Vtec's Avatar
search
Old Oct 17, 2007 | 09:55 AM
anybody know?
LudeLooker
Jun 21, 2013 03:08 PM
seehad79
11
Feb 14, 2010 04:24 PM
strtrcr77
Feb 14, 2008 10:13 AM
Dyzee
10
Apr 28, 2004 11:56 AM
Witty
Dec 7, 2003 10:27 AM
