b18b crank in a b16a
Old Oct 8, 2007 | 03:22 PM
h22swapedsol's Avatar
* B A N N E D *
Default b18b crank in a b16a
b18b crank in a b16a does anyone know if this is possible or has anyone done it if so will it improve hp and torque
Old Oct 8, 2007 | 06:18 PM
* B A N N E D *
Default Re: b18b crank in a b16a (h22swapedsol)
Old Oct 8, 2007 | 06:37 PM
pythoner's Avatar
it would be possible with custom pistons or rods...
check
https://honda-tech.com/zerothread?id=2113653
and learn to search!
Old Oct 12, 2007 | 03:47 PM
soaringchimp's Avatar
Stroker engine!!! As with most stroker cranks, you will need to clearance the block to allow the rods room to spin, other than that you should not have a problem.
Old Oct 12, 2007 | 05:28 PM
UNKNOWN_MEMBER's Avatar
Default Re: b18b crank in a b16a (soaringchimp)
tech43 kit
h22swapedsol
Oct 9, 2007 04:13 AM
CRAZYHONDA
Apr 13, 2005 06:47 AM
integrasaurus-rex
Nov 3, 2004 09:33 PM
DLB1994
Nov 4, 2002 12:14 AM
