Looking for a few Acura Part #s
Looking for part numbers for the following parts:
. front axle 22-1.5mm spindle nut
. front axle hub cap
. shift linkage 8x22m spring
. 3 self-locking bolts for transmission mounts (Helms recommends replacing these when reinstalling transmission)
TIA.
TIA.
TIA.
TIA.
replace locking bolts for tranny? screw that. re-use.
D
if you're just droping the tranny, (1) you dont need to pull your axels, if you do for some other reason, you really don't need a replacement nut. can be reused.
out of the trans yes, out of the hubs no
Does that mean that I do not have to screw around with separating the ball joint too?
Do the drive shaft set rings need to be replaced as per the Helms is is that also overkill?
Does that mean that I do not have to screw around with separating the ball joint too? You still have to seperate the lower BJ.
Do the drive shaft set rings need to be replaced as per the Helms is is that also overkill? Overkill.
1.5mm spindle nut
90305-692-010
front axle hub cap
you mean rear cap? WTF is a FRONT hub cap?
90751-S04-000
90371-SR3-000
90305-692-010
front axle hub cap
90751-S04-000
90371-SR3-000
u do need to pull your axles........
As for the lower ball joint, do it the we-todd way and you can drink beer and put virtually no effort into seperating the lower bj (and do it quickly)..
-Dave, who says "Sometimes a BFH isn't needed
MintyDip
Nov 3, 2003 08:46 PM
