smokein lack of vtec
i have an ls vtec.... *** of late my vtec is not working. i hvae oil i changed ecus and selinoids. i even hooked up a push button tom my vtec selinoid and pressed it when vtec should hit. it didnt.... when i hit where v tec should be i blow allot of white smoke out of my exahust. my car does not smoke untill 5800 and then it blows allot of it what could this be someone help i need my vtec back
White smoke = blown head gasket. This link should solve ALL your ?'s https://honda-tech.com/zerothread?id=1812135
well im not throwing any codes so my oil pressure would not have anything to do with it and if it was a head gasket wouldnt it blow smoke all the time not just at high rpms?
A blown HG can be big and the engine won't run worth a lick, or small and smoke a little bit, even intermittently.
Just because you haven't destroyed your engine running it with no oil until the oil light comes on, doesn't mean you have enough oil.
i have changed selinoids and have even wired them up to a push button and vtec still did not hit if i hook the selinoid to a 12v it should hit no matter what right? would that mean that the selinoids that i put in are junk? i only used used ones how do u know if the selinoid is good before u put it in?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92nahatch »</TD></TR><TR><TD CLASS="quote">when i hit where v tec should be i blow allot of white smoke out of my exahust. my car does not smoke untill 5800 and then it blows allot of it what could this be someone help i need my vtec back</TD></TR></TABLE>
You have bigger problems than a lack of VTEC.
If the wiring and VTEC solenoids are o.k., the problem is oil pressure or mechanical. Locking VTEC pins missing or incorrectly installed, missing o-ring or dowel under #3 cam cap perhaps.
Does your oil pan have any dents in it? I've seen vtec not cross over do to the pan being dented and the pick up is not sucking up enough oil......just a thought
im just going to get a new head gasket and new rings... that way i can get my head machined... i have a eagle stroker kit but i didnt put it in. it was in when i bought the car... if i dont know what the exact part # is, how do i get the correct rings???? help would be apreciated
thanx for all the help so far
how are you running oil to your head? you using the golden eagle kit or a homemade "T" and line?
im sure you did. But, you did plug the vtec oil hole in the head right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92nahatch »</TD></TR><TR><TD CLASS="quote">i had vtec before.... i did not just build a motor and vtec didnt work it worked before</TD></TR></TABLE>
ok
Go fix it then
ok
Go fix it then
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92nahatch »</TD></TR><TR><TD CLASS="quote">i have a eagle stroker kit but i didnt put it in. it was in when i bought the car... if i dont know what the exact part # is, how do i get the correct rings???? help would be apreciated
thanx for all the help so far</TD></TR></TABLE>
i need to know
thanx for all the help so far</TD></TR></TABLE>i need to know
had a friends ls/v have the same prob, tried all of the same things that you did.
Found he had very low oil press, around 15 psi. turned out to be a spun bearing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg »</TD></TR><TR><TD CLASS="quote">You use whatever size rings your pistons are. Are you asking about bearings?</TD></TR></TABLE> i dont know what size they are all i know is that they are 1.95 stroker at 11.5:1 comp
maybe u should read before posting ... the motor is already built if u are going to leave smart *** comments atleast have your facts right before wasting my time
