Hondata Reflash is finally here for the RDX!
The reflash for the Acura RDX is finally here. Although I do not intend on getting this (yet - too new - promised not to modify my new vehicle), I would like to know if people with RDXs (with the *****) that are planning on getting this upgrade. The results are pretty impressive.
http://www.hondata.com/reflash_rdx.html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">The RDX this reflash is tested on, is mechanically stock. This is a must have upgrade. Power gains are everywhere, from a strong increase in low end torque to a good increase in top end power above 5500 RPM.
Rev limiter raised to 7200 rpm. (sportshift mode only)
10-20 Hp gain everywhere - 26 at peak.
33 ft lb torque at 3300 rpm </TD></TR></TABLE>
To be quite honest, assuming that my understanding is correct, the price for
all this:
[-Rev limiter raised to 7200 rpm. (sportshift mode only)]
[-10-20 Hp gain everywhere - 26 Hp at peak.]
[-33 ft lb torque at 3300 rpm]
is a cheap upgrade, without having to change out the downpipe and/or exhaust. Dollar vs. horsepower, $595 for this increase is cheap.
I just need someone to step up to the plate and take a swing at this setup, then post results on a weekly basis.
all this:
rs-sex
Dec 9, 2002 07:53 AM
