Car idles at 4K until warm
Old Oct 8, 2007 | 12:52 PM
ryan_crx's Avatar
Default will someone please help me?
everytime i start my '88 crx it revs to 4000 rpm's til its warm then it will go to a normal ideal? how can i fix this problem?
Old Oct 8, 2007 | 01:11 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: will someone please help me? (ryan_crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryan_crx &raquo;</TD></TR><TR><TD CLASS="quote">everytime i start my '88 crx it revs to 4000 rpm's til its warm then it will go to a normal ideal? how can i fix this problem?</TD></TR></TABLE>
Could be a dirty IACV, although 4K RPM sounds more like a vacuum leak. Did you just do a swap or something? Do you have a Check Engine Light?
Old Oct 8, 2007 | 01:20 PM
ryan_crx's Avatar
Default Re: will someone please help me? (wiZCo)
idk if it has had a swap done to it or not...i have been looking for a vacuum diagram and i cant find one any where
Old Oct 8, 2007 | 01:24 PM
wiZCo's Avatar
Stouts 'n' Scotch
Well, first you need to know what motor you have. Use that link I PMd you and post up your engine code.
What model CRX is it? DX or Si?
Old Oct 8, 2007 | 01:31 PM
ryan_crx's Avatar
Default Re: (wiZCo)
its a dx i think the motor code is d15b2 tho
Old Oct 8, 2007 | 01:35 PM
wiZCo's Avatar
Stouts 'n' Scotch
OK, just a stock motor then. Do you have a Check Engine Light?
There are vacuum diagrams in the CRX workshop manual, you can download it here: http://spoonhonda.com/downloads.htm
Old Oct 8, 2007 | 01:44 PM
ryan_crx's Avatar
Default Re: (wiZCo)
yeah i have a check engine light its blinks 1, 3, 5
Old Oct 8, 2007 | 02:00 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (ryan_crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryan_crx &raquo;</TD></TR><TR><TD CLASS="quote">yeah i have a check engine light its blinks 1, 3, 5</TD></TR></TABLE>
#1: bad O2 sensor or wiring
#3 and #5: Bad MAP sensor, could also result from having the vacuum lines hooked up wrong.
Download that CRX workshop manual and see if your vacuum lines are routed properly. Or take a pic of your lines and post them.
Old Oct 8, 2007 | 02:27 PM
SIred91's Avatar
Rainman
Default Re: (wiZCo)
Hmm, what about bone stock never touched? No codes.
High idle (3k) till warm, then normal.
Old Oct 8, 2007 | 08:03 PM
ryan_crx's Avatar
Default Re: (SIred91)
its not stock...i have a filter...header and down pipe...and a can
SIR_APPROVED
16
Nov 25, 2010 01:01 PM
Hondamasteracer
Jul 16, 2009 09:31 AM
Phrost
Aug 1, 2007 06:31 AM
CRXDaddy78155
Sep 4, 2006 11:42 AM
