gsr head on a b16a2 block
Old Oct 8, 2007 | 07:58 AM
MOST's Avatar
Default gsr head on a b16a2 block
have a 00 civic si wanted to know if i could put on a gsr head on the b16a2 block?
Old Oct 8, 2007 | 07:59 AM
stock99si's Avatar
Default Re: gsr head on a b16a2 block (MOST)
yea u can. but theres no purpose of that because the b16 head is bbetter.
Old Oct 8, 2007 | 08:08 AM
MOST's Avatar
Default Re: gsr head on a b16a2 block (stock99si)
i heard the same thing about the b16 head. will it make it run poor will it give it a bit higher compression? or should i just look 4 a b16 head?
Old Oct 8, 2007 | 09:46 AM
Blk00EJ8's Avatar
Someone correct me if I'm wrong but the GSR head should lower compression a few tenths, no?
Old Oct 8, 2007 | 11:13 AM
00Red_SiR's Avatar
All Motor Mentor
Default Re: gsr head on a b16a2 block (Blk00EJ8)
GSR head will increase compression by .2 points. The problem is that you will need to buy an aftermarket intake manifold like the skunk2 designed to fit the GSR head (IM bolt pattern). The GSR stock intake is good but the secondary butterflies won't work on a b16a ecu. The Type R style intake manifold usually loses power on a b16a in the lower end/mid-range, only better in the top end so unless you add cams to the b16a and a tuning system like Hondata you won't be able to take advantage of any of the mods.
Old Oct 8, 2007 | 11:34 AM
stock99si's Avatar
Default Re: gsr head on a b16a2 block (00Red_SiR)
in my opinion, get a b16 head. you wont have to mess around wiht ecu and all that **** if u do.
Old Oct 8, 2007 | 11:36 AM
fmrprojects's Avatar
what is wrong with your head? just get it fixed and it will be better than buying a used head
Old Oct 8, 2007 | 09:02 PM
Blk00EJ8's Avatar
Yes, good points 00Red_SiR. I completely forgot about the IM difference and I did a GSR swap myself. Bah, I went with a Skunk2 piece (B16/R style) and that alone would offset the cost of swapping heads if there was any savings to begin with.
408EJ1
16
Jan 8, 2014 03:23 PM
newbie1
Jan 8, 2008 10:28 AM
EFin' Kyle
Jul 26, 2004 10:09 PM
BoOsTeD_eK
Jun 14, 2002 06:56 PM
Petah
Oct 27, 2001 09:19 AM
