jack stands
Old Oct 8, 2007 | 02:47 AM
DEPintheCurve's Avatar
Default jack stands
I am attempting to get under the car, so i just bought two jack stands. the instuctions for the jack stands suck, and i am a little afraid to place them just anywhere. Is there any place on my CRX, other than the reinforced jack ports under the doors, where I could set the jacks? Thanks for any help you can give...
Old Oct 8, 2007 | 03:33 AM
TylerB's Avatar
Default Re: jack stands (DEPintheCurve)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DEPintheCurve &raquo;</TD></TR><TR><TD CLASS="quote">other than the reinforced jack ports under the doors</TD></TR></TABLE>
Try there first?
Old Oct 8, 2007 | 07:30 PM
Default Re: jack stands (TylerB)
well that was what i was thinking but i have to use the port to lift the car first with the jack itself. there is not enough room on the port for both the jack and the jack stand. i tried that already...
Old Oct 8, 2007 | 07:34 PM
alscrx's Avatar
You lift the car with a piece of wood on the rails. So once its up in the air you place you jack stands on the free reinforcements. Release the tension on the jack!
Wood is your friend
Old Oct 8, 2007 | 07:50 PM
SIred91's Avatar
Rainman
Default Re: jack stands (alscrx)
Jack the car from the front crossmember.
Old Oct 8, 2007 | 08:06 PM
Hondacivic90ed's Avatar
Default Re: jack stands (SIred91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">Jack the car from the front crossmember.</TD></TR></TABLE>
x2
Old Oct 8, 2007 | 08:08 PM
crazykamper's Avatar
^^ X3,
if ya do that, then the whole front is in air (dont forget the e-brake!!) and then put the jack stands either under the frame rails or the oem jack mounts, rails preffered...
Old Oct 8, 2007 | 08:26 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (crazykamper)
jacking from the front cross member works great.
if you have a crappy jack, which i assume you probably do (I was there once also..), then jack it from the side with a peice of wood and then put the jack stands under the jack points like someone above said. Good luck, and be safe.
mg23
Jan 6, 2008 05:10 PM
cpforyou
Aug 19, 2006 08:04 PM
H.
Dec 15, 2005 06:48 PM
STAGE 2
Aug 4, 2004 04:53 PM
Stinkycheezmonky
Apr 7, 2004 07:38 PM
