Fuel pressure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rosko »</TD></TR><TR><TD CLASS="quote">You need an adjustable regulator. Why do you need to adjust fuel pressure anyways?</TD></TR></TABLE>
yeah, why u wanna turn up your pressure anyway..?? don't do anything too crazy!
32psi isn't it suppose to be??? I can't remember, too many btu's, and hp's, and watt's and ohm's and amps, an volts bwah bwha bwha *edit*...beers??..who the f* knows
happy octoberfest btw to all who celebrate! If not , have a beer anyway, I'm sure everybody here earns them.
Nope, thats ridiculous.
Only time you should ever need to change fuel pressure is if you have changed fuel pumps and need to re-regulate the flow, or you are maxing out your injectors and need just a little more oompf out of them. Yes it is a way of tuning but that SHOULD all be handled via the ecu and not by adding fuel pressure. Otherwise just adding fuel pressure for the hell of it will cause you to run rich and will more than likely cause you to lose power.
and snooz it should be 43ish psi or 3 bar
the only time u need more fuel is if you either have a built motor,boost, or nitrous. If you have a stock motor it will just flood it out and run like ***. Plus even if you turn them up the injectors only push a certain amount so it would do any good anyway. If you want more HP get a intake and full exhaust and plug wires and plugs those are the best first mods and the best if you ask me.
43 psi? for both h23 and h22? (just curious)
Allthough if you are running lean, fpr's can help could they not??or, even if your runnin rich aswell
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattsnooz »</TD></TR><TR><TD CLASS="quote">
Allthough if you are running lean, fpr's can help could they not??or, even if your runnin rich aswell </TD></TR></TABLE>
If you're running rich or lean you have other problem you need to fix rather than adjusting the fuel pressure (on a mostly stock/bolt-on engine anyhow)...
