k20 in eg hatch
Old Oct 7, 2007 | 07:17 PM
slo_hatch's Avatar
Default k20 in eg hatch
i think im gonna try to pick up a k20 to put in my eg hatch. i was curious on a 1-10 scale how hard this swap is. and also what i will need to do this swap. money is definitely an issue too!! thanks guys.
Old Oct 7, 2007 | 07:22 PM
lhmoobvaj's Avatar
Default Re: k20 in eg hatch (that_eg_hatch_guy)
Sorry, but you've already answered you're own questions. It takes a whole lot of money, time, parts, converting, knowledge, and RESEARCH. The engine alone is about 5k, plus you'll needs parts, etc.... Check out k20.org!
Old Oct 7, 2007 | 07:31 PM
SoullessJapaneseMachine's Avatar
Default Re: k20 in eg hatch (lhmoobvaj)
its a lot of custom work..the opposite of plug-n-play
basically get ready to weld.. cut... measure... fab...make mistakes...do again...etc
Old Oct 7, 2007 | 07:35 PM
posHonda's Avatar
If money is an issue than dont do it. IMO a k20 swap is all bragging rights. For the price of a k20 swap in a hatch you could have a built and boosted B series.
Old Oct 7, 2007 | 07:37 PM
slo_hatch's Avatar
well i actually know a guy that i can get the motor for a STEAL!!! it was blown but the guy said it had a new block and high compression pistons and everything needed....motor, 6-speed tranny, ecu, wiring harness. i think i just need mounts, some kind of harness, and TIME!! but this is the ideal swap for me so i hope it works out.
Old Oct 7, 2007 | 07:39 PM
posHonda's Avatar
Getting the motor for a steal might make it ~$2k less probably?? If you insist than go ahead because theres nothing wrong with having a k20 hatch. I just think the time and money could be better spent elsewhere.
Old Oct 7, 2007 | 07:48 PM
slo_hatch's Avatar
Default Re: (iVteC_PoWeR)
well the guy said that i could get it for like 1800. it is disassembled but has everything. it also comes with a bunch of aftermarket parts. so i think its a good deal. im thinkin 1800 for k20 motor, 6speed tranny (w/ lsd), wiring harness, and ecu.....then mabye 700 for mounts ....then 350 for some wiring thing he said i needed.....and maybe 500 to have it assembled. im afraid to do it cuz i will prolly put something on wrong and blow it up!! so im hoping to get away with about $3600 all together. thats cheaper than a junkyard wants for the full swap (w/o mounts and assembly and special harness thing). also the junkyard k20's are supposed to have like 20-30k on them. this motor will have 0. lol
Old Oct 7, 2007 | 07:51 PM
161822's Avatar
Default Re: (that_eg_hatch_guy)
if the motor is that cheap u may want to look deeper into it. it seems too good to be true, but maybe u got lucky!!!!
Old Oct 7, 2007 | 07:58 PM
posHonda's Avatar
Well dont waste a k20 by not knowing how to build it lol.
Old Oct 7, 2007 | 08:43 PM
Libertariat's Avatar
Ek Forever y0!
It's one of the most difficult honda/honda swaps there are.
In the 4cyl range.
I've helped do a number of swaps, and most people will agree with what is the hardest/easiest.
From hardest to easiest.
k20/k26>k20>f2d/h2d>h/f>h2b/f2b>b>d
Essentially. If I left something out and it's totally obvious, cut me some slack. It's 1 am here.
Old Oct 8, 2007 | 05:09 PM
slo_hatch's Avatar
anyone got any more answers or opinions??
Old Oct 8, 2007 | 05:24 PM
Boost_V's Avatar
I might actually go with that. Sure it's difficult, but that's why we research. Just make sure the motor actually isn't stolen.
Old Oct 8, 2007 | 05:34 PM
ekb16's Avatar
new mounts, shift mounting kits to mount the new shifter box, new axles,PnP harness, new fuel setup, new exhaust setup
Old Oct 8, 2007 | 06:10 PM
97Ej6mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by that_eg_hatch_guy &raquo;</TD></TR><TR><TD CLASS="quote">. i was curious on a 1-10 scale how hard this swap?</TD></TR></TABLE>
a 12
allot of research and learning
and about $7000 laying around to goto use
Old Oct 8, 2007 | 07:02 PM
Ek Forever y0!
Default Re: k20 in eg hatch (97Ej6mike)
LOL I just put this together.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by that_eg_hatch_guy &raquo;</TD></TR><TR><TD CLASS="quote">i think im gonna try to pick up a k20 to put in my eg hatch. i was curious on a 1-10 scale how hard this swap is. and also what i will need to do this swap. money is definitely an issue too!! thanks guys.</TD></TR></TABLE>
Access Level Normal User
Permission Level Restricted Trial User
Full Name Roy Edwards
Email Address [Hidden]
Location Johnson City TN 37601
Age 17
Good luck with your $8,000 swap buddy. Go read another Honda-Tuning issue.
Old Oct 8, 2007 | 07:18 PM
posHonda's Avatar
lol every high schooler wants a k20 swap in their honda. There actually was one kid with a k20 swapped crx in my district a few years ago.
A k20 swap IMO isnt practical. No doubt they are better than the B series but for now theyre too expensive. Swap in a gsr and turbo that. Itll be faster, cheaper, and easier to do.
Old Oct 8, 2007 | 07:42 PM
DOHCVTEC!'s Avatar
u gotta pay if u wanna play, k20 all da way!!!!
Old Oct 8, 2007 | 07:45 PM
posHonda's Avatar
Default Re: (DOHCVTEC!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCVTEC! &raquo;</TD></TR><TR><TD CLASS="quote">u gotta pay if u wanna play, k20 all da way!!!!</TD></TR></TABLE>
Ill pay for a gsr turbo instead and walk all of you with k20 swaps
Old Oct 8, 2007 | 07:55 PM
pennies_hatchie's Avatar
Default Re: (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">It's one of the most difficult honda/honda swaps there are.
In the 4cyl range.
k20/k26&gt;k20&gt;f2d/h2d&gt;h/f&gt;h2b/f2b&gt;b&gt;d
Essentially. If I left something out and it's totally obvious, cut me some slack. It's 1 am here.</TD></TR></TABLE>
Its not hard at all and it is plug and play as long as you have $$ to buy everything
Old Oct 8, 2007 | 11:30 PM
pho dac biet's Avatar
Hair Club President
if you dont know what you're getting your self into.. dont even try.. especially if you dont have the funds
Old Oct 8, 2007 | 11:48 PM
jdmxsoles's Avatar
pretty much if funds is a issue why are you even trying this and if you really want to do it gtfo of h-t and go to k20.org they have a how to and everything you need for a k20 in a eg look at it understand it and if you think you have the knowledge tools and money then do it ! GL
Old Oct 9, 2007 | 06:10 AM
Ek Forever y0!
Default Re: (jdmxsoles)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pennies_hatchie &raquo;</TD></TR><TR><TD CLASS="quote">Its not hard at all and it is plug and play as long as you have $$ to buy everything</TD></TR></TABLE>
Sure it can be plug and play. If by plug and play you mean plug $10,000 into a mechanics hand.
Old Oct 9, 2007 | 06:37 AM
Rok_Stok's Avatar
Another thing is that is your car hatch has ABS, you will need to take it out and either find brake lines from a non-abs hatch or make them yourself. This is so the header will fit.
Old Oct 9, 2007 | 06:49 AM
slo_hatch's Avatar
i have a ballpark estimate of about 3k after everything....motor, tranny (w/ lsd), ecu, wiring harness=1800, mounts=650, special wiring harness=350??, maybe some other pieces....but i have heard that the mounts and wiring are the hardest thing about the whole swap. i mean this is the ideal swap for me. plus the motor has 0 miles on it....its still disassembled with high compression pistons and all that good stuff. i know that alot of teens want k20s but my cousin has an 05 civic si hatch and i fell in love with the power and sound from a k20....i think this is the more realistic swap for me....even if it does cost a shitload!!
Old Oct 9, 2007 | 09:08 AM
themikewoo's Avatar
Scale of 1 - 10.
A solid 10.
