p28 red line at 6400???
Old Oct 7, 2007 | 03:08 PM
luvmihatch's Avatar
Default p28 red line at 6400???
ok so i got a p28 in my single cam. DD. dont drive the car hard.. red lined it today and it topped out at 6400 what could be the problem i thought 7ish was red line.. and ideas.
Old Oct 7, 2007 | 03:27 PM
4DRmafia's Avatar
yea, :/ wtf my 4dr ex is the same way. i was like wtf
Old Oct 7, 2007 | 03:30 PM
luvmihatch's Avatar
Default Re: (TealSpoon)
did u fix it.. or u still having the problem
Old Oct 7, 2007 | 03:40 PM
ke98248's Avatar
Default Re: p28 red line at 6400??? (luvmihatch)
that's sounds about right for a 5th gen civic, but my 97 civic ex coupe redlines just at 7k
Old Oct 7, 2007 | 03:42 PM
luvmihatch's Avatar
Default Re: p28 red line at 6400??? (ke98248)
yeah thats what i was thikin.. still sucks *** tho. ohh well bout ot bet boosted some day soon. thanks for the help guys
Old Oct 7, 2007 | 03:43 PM
jamesc2123's Avatar
if its the d16z6 ( i dont know what engines the the p28 goes in) it should redline at 7200 with the rev limiter right around there. is it an auto or manual, as i know some automatic trannys will shift before redline
Old Oct 7, 2007 | 03:44 PM
ke98248's Avatar
Default Re: p28 red line at 6400??? (jamesc2123)
the p28 ecu goes in the d16z6, from 92-95 civic ex coupe
MORE INFO:
D16Z6
* Found in
o 1992-1995 Honda Civic (ex/si)
o 1993 Honda Del Sol Si (only USDM)
+ Displacement : 1590 cm³
+ Bore and Stroke : 75 mm X 90 mm
+ Compression : 9.4:1
+ Power : 125 hp (93 kW) @ 6500 rpm & 106 ft·lbf @ 5200 rpm
+ Redline : 7200 rpm
+ Fuel Cut : 7411 rpm
+ VTEC Switchover 4800 rpm
+ Valvetrain : SOHC VTEC
+ Fuel Control : OBD-1 MPFI
+ Head Code : P08
+ Head Code (EU): P28
Old Oct 7, 2007 | 03:48 PM
4DRmafia's Avatar
umm well my cel is on tho, does it kick back the redline until i fix my cel problem ?
Old Oct 7, 2007 | 03:53 PM
luvmihatch's Avatar
yeah i have the z6.. just wondering y its still not goingto 7200..
fryman
Jun 24, 2008 04:07 AM
95lscivic
Jun 26, 2007 09:44 PM
Cashieboi
Sep 27, 2005 05:53 AM
hybridEj6
Apr 19, 2003 06:54 PM
