Lighting HID/Xenon kits, Retrofits and Associated Topics
can you hard wire eg6 foglights ???? to run either when lights come on or all the time???
Old Oct 7, 2007 | 02:35 PM
4gencivicef9's Avatar
Default can you hard wire eg6 foglights ???? to run either when lights come on or all the time???
I am trying to hook up my fogs either all the time, or when the lights are on
Old Oct 7, 2007 | 03:06 PM
BlueIntegraBoy's Avatar
Default Re: can you hard wire eg6 foglights ???? to run either when lights come on or all the time??? (4genc
Yes, but I'd run a relay and inline fuse to a switch.
Old Oct 7, 2007 | 03:21 PM
can you explain how I would do this....or send me a link
Old Oct 7, 2007 | 05:09 PM
forcefedferio's Avatar
i've done it before, kinda ghetto but it works
i basically just grounded the ground wires to the rad support, spliced the power wires together and spliced them into the low beams for the right or left side headlight and put in a larger amp fuse into the fuse block....this is because i didn't get a switch and harness with my foglights because they came in a bumper from passwordjdm.
Old Oct 7, 2007 | 06:24 PM
word thanks man
Old Oct 13, 2007 | 09:54 PM
hard wired my fogs, and got another problem, everthing was good, and working. then went home and I smelled this weird smell and I knew it was that so I reached down and touch the wire and it was hot, not to hot but enough for me to unplug it.....
any thing I can do here...:
Jlove1993
12
Aug 15, 2015 05:11 AM
jawsiiv
Jun 8, 2010 02:24 PM
xmilanoredsix
Jul 1, 2005 06:33 AM
cvcrcer
Mar 31, 2005 06:04 PM
xsuperdanx
May 11, 2003 04:31 PM
