Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
07 Civic Premium Audio and DRM
Old Oct 7, 2007 | 11:54 AM
ccope47's Avatar
Default 07 Civic Premium Audio and DRM
Made copies of 4 of my CD's using Window Media Player and then copied to new CD's using WMA format. Tried to play in Honda Premium Sound System and it would not play. Said format not supported as a result or Digital Rights Management (DRM). Hey these are my CD's! Can I turn this feature off?
Old Oct 7, 2007 | 03:10 PM
drkangel650's Avatar
Default Re: 07 Civic Premium Audio and DRM (ccope47)
personally I've only used one 'real' CD. I rip all of mine immediately and store them to prevent damage so as to always have a hard copy.
Chances are it is the program, not the car. My 07 EX is perfectly fine with them.
Thats the settings for I-tunes. I used to be a die hard WMP user til the upgrade. i-tunes works well enough
Old Oct 8, 2007 | 09:46 PM
av911's Avatar
Try to lower the bit-rate on the WMA files.
Old Oct 9, 2007 | 04:46 AM
ccope47's Avatar
Default Re: 07 Civic Premium Audio and DRM (drkangel650)
Thanks for your response. Forgot to mention that I have a lot of tunes on windows media player, scrambled and ranked, so I probably have to use this software? Also, used loss less wma compression.
Old Oct 9, 2007 | 06:38 AM
nightryder21's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccope47 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for your response. Forgot to mention that I have a lot of tunes on windows media player, scrambled and ranked, so I probably have to use this software? Also, used loss less wma compression.</TD></TR></TABLE>
Thats your problem. The Civic can not read lossless mp3s. The max bitrate they can read is 320mbs if im not mistaken.
Old Oct 9, 2007 | 10:05 AM
Declectic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccope47 &raquo;</TD></TR><TR><TD CLASS="quote">using Window Media Player</TD></TR></TABLE>
that's your problem right there, that program is no good!
Use:
• Roxio
• Nero
• iTunes
Old Oct 9, 2007 | 10:59 AM
Default Re: 07 Civic Premium Audio and DRM (SeanJohn1802)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SeanJohn1802 &raquo;</TD></TR><TR><TD CLASS="quote">
Use:
• Roxio
• Nero
• iTunes</TD></TR></TABLE>
Wrong. Its the bit-rate. Besides, since he uses wma-lossless, he can't use itunes.
Old Oct 9, 2007 | 11:02 AM
Default Re: 07 Civic Premium Audio and DRM (nightryder21)
To help avoid re-riping you CDs. Go to options and tell it when you burn data CD's to burn the music at bitrate of 192.
Modified by nightryder21 at 10:58 AM 10/10/2007
jason66
Jul 11, 2011 11:51 AM
twmccoy
Honda Civic (2001 - 2005)
May 14, 2007 12:39 PM
ohmide
May 26, 2006 08:34 PM
civicboy95
Audio / Security / Video
May 26, 2004 11:51 AM
