FYI: If you have problems bogging with partial throttle but not when cold
It is your o2 sensor!
I thought I had an issue with my fuel pump or injectors.
Turns out two wire leads off the o2 sensor were loose. It wasnt showing a check engine light.
It would only happen when the car was warmed up and not when cold. I would be driving on the freeway and under load the car would bog big time. But when I got on the gas it would be fine.
Hope this helps someone out if they ever have similar issues
yah that is what bugged me. No CEL at all. Drove around with it for a couple days. I am guessing that whatever the ECU looks for to throw a CEL, it must have had those two wires connected
apoptosis
Jan 21, 2008 08:33 PM
crxforum
Aug 30, 2004 07:01 AM
