door lock problem
Old Oct 7, 2007 | 10:25 AM
jr000's Avatar
Default door lock problem
so my door lokdoesnt unlock when i push the switch on my door panel, thought it was the door lock control in the door but i changed it and it wasnt that...the dirvers side unlocks/locks fine but the passenger side doesnt work at all...is there a fuse somewhere for the passenger side? thanks!
Old Oct 7, 2007 | 10:26 AM
jr000's Avatar
Default Re: door lock problem (jr000)
oh and its for a 1996 honda civic ex coupe
Old Oct 10, 2007 | 10:48 AM
jr000's Avatar
still cant figure it out
Old Oct 10, 2007 | 10:52 AM
ukdmegg5's Avatar
Fuses for the door lock are drivers side under dash if that doesnt work take the door card off and have a look at the mechanism see if its damaged or worn
Old Oct 10, 2007 | 10:58 AM
Hardedge's Avatar
While we're on the subject, sometimes my driver's door doesn't lock or unlock with the remote. I looked at the manual switch and it seems to get stuck halfway through its travel and resists being pushed on. Where should I start? By the way, '00 Civic Si.
Old Oct 10, 2007 | 11:13 AM
monicle's Avatar
Default Re: (Hardedge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hardedge &raquo;</TD></TR><TR><TD CLASS="quote">While we're on the subject, sometimes my driver's door doesn't lock or unlock with the remote. I looked at the manual switch and it seems to get stuck halfway through its travel and resists being pushed on. Where should I start? By the way, '00 Civic Si. </TD></TR></TABLE>
shut your door and it will work fine heh<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jr000 &raquo;</TD></TR><TR><TD CLASS="quote">so my door lokdoesnt unlock when i push the switch on my door panel, thought it was the door lock control in the door but i changed it and it wasnt that...the dirvers side unlocks/locks fine but the passenger side doesnt work at all...is there a fuse somewhere for the passenger side? thanks!</TD></TR></TABLE>
there is only 1 fuse for the locks, id say youve either got a wiring problem or the actuator itself may have gone out. you can test continuity from the actuator to the control box to test your wiring.
Old Oct 10, 2007 | 06:21 PM
Hardedge's Avatar
Default Re: (monicle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monicle &raquo;</TD></TR><TR><TD CLASS="quote">shut your door and it will work fine heh</TD></TR></TABLE>
Oh, right, I didn't try that...Why isn't there a "rolls-eyes" smiley?
Anyway, when the door is closed as you would normally do when locking the car, I hit the button on the remote to set the alarm and lock the doors. However, sometimes the driver's door refuses to lock. It seems to just be getting stuck through it's travel.
Old Oct 11, 2007 | 06:24 AM
monicle's Avatar
Anyway, when the door is closed as you would normally do when locking the car, I hit the button on the remote to set the alarm and lock the doors. However, sometimes the driver's door refuses to lock. It seems to just be getting stuck through it's travel. </TD></TR></TABLE>
you might be suprised on how many times that "issue" has come up before.
when youre inside the car do you feel any sort of drag or hesitation if you manually move the lock lever?
Old Oct 14, 2007 | 09:46 AM
jr000's Avatar
how do i check for it? well originally i thought it was the door lock control behind the door panel...so i bought one and its still doing the same thing...the drivers side door works but the passenger doesnt...however i replaced the door handles in the inside because they were all messed up but it worked fine after i replaced them...not sure which wires go to the pass. side and which go to the drivers....
Old Feb 11, 2008 | 06:54 PM
jr000's Avatar
Default Re: (jr000)
still cannot figure this out...anybody? help?
Old Feb 14, 2008 | 06:41 PM
stck94cpe's Avatar
Default Re: (jr000)
I would def try replacing the lock-actuator if nothing has helped yet. I replaced mine yesterday, and i had the exact same problems as you. It runs about $150 from the dealer... hope this helps...
Old Feb 17, 2008 | 05:29 PM
jr000's Avatar
Default Re: (stck94cpe)
bump and damn....i will just look at a junkyard...do you know the part number?
Old Feb 26, 2008 | 07:18 AM
CplNet's Avatar
im with the same problem..
my rear door dont lock..
i think its the actuator.. someone have the part number?
there is some way to fix the actuator ?
rfmc9081
Honda Civic (2001 - 2005)
Mar 24, 2014 12:45 PM
2003CivicLx
Sep 18, 2008 05:14 PM
RedKroovy
Nov 13, 2005 08:54 PM
