What filler rods do I use to weld aluminum to steel?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FastCougar »</TD></TR><TR><TD CLASS="quote">You can't weld dissimilar metals together like that. Aluminum will not weld to steel.</TD></TR></TABLE>
I was wondering about this and thought it would be stupid to ask but now I feel like less of a dumbass now
You can use high explosives to weld aluminum and steel...the after product is called "clad" and is used in places like nuclear power and chemical plants.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k24em2 »</TD></TR><TR><TD CLASS="quote">You can use high explosives to weld aluminum and steel...the after product is called "clad" and is used in places like nuclear power and chemical plants.</TD></TR></TABLE>
Wow thats a different type of welding? What is used to do that ? Just curious.
you lay the two sheet metals on top of each other, and then build a wooden curb ontop of the sheet metal around it like an outer frame. and fill it with explosive then ignite. the explosion causes the two metal to press into one another
it is no longer used in most nuclear power areas and it is not ideal or a good process
At work when we do aluminum to aluminum we use 50 series if I am not mistaking we also have a 40 series rod too
So much trouble... We get tons of steel welded to aluminum here. It's called Aluminized steel piping
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tony the Tiger »</TD></TR><TR><TD CLASS="quote">
Haha little difference there!
</TD></TR></TABLE>Haha little difference there!
there is a way to fuse aluminum to steel.. a semi-trailer manufacturer that I sell has it patented. They fused aluminum crossmembers to their steel frame.
Midship...just so you know also, there are a couple places online that'll sell you any v-band combo you want without a change in price....so you can get one aluminum side and one steel side with the clamp. So if you do an aluminum exhaust you can connect it to the stainless dp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dmotoguy »</TD></TR><TR><TD CLASS="quote">there is a way to fuse aluminum to steel.. a semi-trailer manufacturer that I sell has it patented. They fused aluminum crossmembers to their steel frame. </TD></TR></TABLE>
friction "welding" can be used to join aluminum to steels. Some cars use it like you mentioned with trucks.
.john.
Welding / Fabrication
Sep 4, 2007 06:39 AM
Justin Olson
Sep 25, 2005 06:00 PM
SuperTuner
10
Nov 16, 2004 10:41 PM
