extended top hats
Old Oct 6, 2007 | 11:49 PM
kixcrx's Avatar
Default extended top hats
anybody know where i can buy extended top hats for a 90 crx
Old Oct 6, 2007 | 11:59 PM
Pee Wee's Avatar
Default Re: extended top hats (kixcrx)
Ground Control, now go wash the spoon i just dirtied up feeding your ***
Old Oct 7, 2007 | 12:19 AM
kixcrx's Avatar
Default Re: extended top hats (Pee Wee)
it says that those top hats only fit ground control is that true cause i have some no name coilover springs and i was wondering if those top hats would fit
Old Oct 7, 2007 | 10:26 AM
bigluelok's Avatar
You could search for username misha and also look for ef_sedan reply in one of his threads and look up his build thread and there's a link to a diy for the top hats but you'll have to read
edit: found the link for you so now you have to read
https://honda-tech.com/zerothread?id=469485
Modified by bigluelok at 8:31 PM 10/7/2007
Modified by bigluelok at 8:32 PM 10/7/2007
Old Nov 23, 2007 | 12:03 AM
kixcrx's Avatar
Default Re: extended top hats (bigluelok)
ok so im thinking of buying some extende top hats from ground control but it says they only fit ground control is this true cause i have new stock shocks and no name coil overs will they fit.
Old Nov 23, 2007 | 08:31 PM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kixcrx &raquo;</TD></TR><TR><TD CLASS="quote">ok so im thinking of buying some extende top hats from ground control but it says they only fit ground control is this true cause i have new stock shocks and no name coil overs will they fit.
itll work with crappy skunk2/omni/ebay coilover kits. at worst, youll have issues with the inner diameter not fitting properly, but itll still work.
shouldnt be used with any regular spring kit. (unless you cut some springs...)
super_nguyen
Suspension & Brakes
Feb 25, 2006 03:02 AM
Understeer
Apr 22, 2004 10:30 AM
ANGELIQUE
Mar 31, 2004 09:19 AM
