need info on swapping d15b7 block (obd1) in a obd2 car
Whats up guys, I did a bit of searching on this matter but couldnt seem to find all the answers. Just need to clarify a few things here, I have a d16y8 with a obd1 conversion on a p28 ecu and want to swap out the block for a built d15b7 block (obd1) onto my y8 head. Now, for the wiring, if im not mistaking, I beleive this block doesnt have a knock sensor and a crank angle sensor, how do i overcome this problem ?
as for the vtec, if im correct, i think this block isn't designed for it, so what must be done to the block in this situation ?
as for the head to work on this block, from what I've read, I beleive the only thing that must be used is a d16z6 timing belt ? for the rest, all the y8 components must be used, does this seem correct ?
let me know if im missing anything here thanks
it has everything done except for sleeves and yes its worth it, and im quite sure it has been done before but im not sure on the exact procedure, thats where I need some advice
Littleredsi
May 30, 2004 10:06 AM
